luei74
- Aug 5, 2001
Thanks. Think later versions of mi flash can support 32 bits and 64 bits. Just a word of caution to check you are using the latest version of mi flash to flash.
I'm using the XiaoMiFlash(Beta) [I recall that initially only the Beta version was able to flash in EDL mode on Mi-Max locked boatloader], refer to the following screen shot.
I never follow up on the latest MiFlash latest version as I'm currently with the global stable rom. You might need to do some read up in the MIUI forums to check if there's any changes..
