gaoxing84
- Feb 12, 2004
Thanks for the sale. Ordered MM
No problem! Thank you boss!
hi gaoxing, i just bought the uevo dry wax from you.
Perming my hair did wonders
May need to get the seasalt spray when I finish my sidekick.
Looks natural but abit dry.
Sure. Sure. Hoot more Haha
Whats the diff between MM Chrome and treatment?
Which one is more suitable for fine hair?
I have a undercut hairstyle and currently using baxter clay, but the wash-ability i buey tahan, too oily.
Currently clay pomade sticks to my hair quite nicely, albeit sometimes dropping off, but the restyle-ability not there also. Basically pray that my hair walk out swee swee.
Can MM do that?
Yes of course. Why not
Any specific instructions on using MM as compared to other products?
Mostly see alot of good reviews for those who took the plunge but got 1 or 2 people mentioned that it didnt work for them :O
Vilain black Fiber got any reviews?
So where should I get the MM or HDF? I'm using Uevo grey now
Yeah! The hold doesn't stay the entire day though... Do need to adjust. Just itching to try other stuff too
for me it does.
why not give morris motley treatment styling balm a shot?
used uevo grey but still need hair spray to lock the style.
Any hair spray to recommend?
why need spray?
the uevo grey have fixated properties, add spray already it will look unnatural bro.
