Hi bro, doesn't stay. Hair still fall down.
thinking of getting a mousse also.
Sea salt for wilder hair
mousse for sleek
Bro gaoxing, which is your store?
your hair fall as in strands of it fallen down or its flatten?
strands falling down.
For MM, is it advisable to use hair spray?
Personally, MM is the only product i have used that is able to hold my hair without hairspray. Sorry to butt in
What is MM full name?
Means your few strands is not long enough.
Very normal. I would suggest against hair spray.
Looks damn unnatural.
Defeat the purpose of restyling ability of the product
Can uevo grey be used with morris motley treatment balm? If yes, how to use both together?
What are the differences of MM vs uevo grey?
Is MM greater holding power than uevo grey?
Is MM harder to wash off?
Morris motley is entering wholesale for Asia. So for those who always wanted to try but on budget, rejoice soon. Pray price will drop to 35-40 ish, affordable enough to buy 1 tub every 2- 3 months. Source: their insta
Uevo Grey
Morris Motley Treatment Styling Balm
After opening does the products still expire according to the expire date printed?
After opening, how long can the product last (become bad, cannot use anymore) from opening date?
What are the differences of:
1. Morris Motley Treatment Styling Balm
2. Morris Motley Chrome (Shine Finish)
What "treatment" properties does Morris Motley Treatment Styling Balm have?
Does Morris Motley Treatment Styling Balm makes hair look shiner (oilier) than Uevo grey?
Uevo grey more matte look?
