LG V20
Singtel
Suspended
I just came back from JUrong Point....waa the queue at SingTel is terrible...
I asked the CSO there about the VoLTE and he says it network dependent :s11::s11:
Says SingTel has been doing trial at Jurong East Central region and so 4G phone should be able to recieve VoLTE .... hahahaha... sorry I dunno why I'm laughing at what I type :s13:
Hi Anything_Whatever,
We would like to clarify on our 4G ClearVoice service.
As the name suggests, the service is based on Voice over LTE technology and is fully integrated with the voice service.
It is available on all Combo Mobile plans, SIM Only plans and Easy Mobile plans on supported handsets.
To enable 4G ClearVoice on your LG device, go to Settings > More > Mobile Network > Toggle the VoLTE checkbox.
For more information on our 4G ClearVoice, you can check out the link below:
https://www.singtel.com/personal/4g/service-features.html
Anything_Whatever
Thank you for clarification, it's good to have a SingTel spokesperson here in HWZ.
You explain better than the CSO ...
BananaMilkShake
So as long as we toggle on the VoLTE, even without the icon appearing at the statusbar, as what we seen from the post above, it is already on? Or the icon must appear at the statusbar?
Its because I did not see the logo appearing even after toggling it on.
hinamoriamu
Will ST Hi Prep card also support VoLTE?
SpaceMonkey
Looking at the charge at this speed is it normal?
Quite slow lei. :/
Sent from LGE LG-H990 using GAGT
Jhawk55
Hi Singtel, I am on Singtel combo 3 but I can't get VoLTE to work on my V20. So is this a handphone hardware or faulty sim issue? What can I do on my part? Thanks.
tnchsg
install gbwhatsapp for 2nd line or install parallel space to login 2nd account, but i prefer the 1st option
both no root required
lgmw33
Kind of strange that some v20 do not have the volte icon displayed on status bar, even though volte was toggled n selected.
shager
Yes, I'm on SingTel Combo and my VoLTE is clearly indicated. Have you tried going down to Hello shop to see if they can help?
Tsoukalos
ok, i gotch a problem.
i formatted new sd card as above so it's now ex-fat w default allocation size then my old sd card is fat32 with 32kb allocation size. i tried to copy data over from old to new sd card but keep getting device has stopped responding or has been disconnected. issit due to my new sd card format or other reasons? i've tried swapping sd card reader & cables liao.
Anything_Whatever
Why not try format with your LV20 instead of from your PC ?
spectral
so strange, I do have the volte icon but there is not a volte option when I followed ur instructions to find it.
Tsoukalos
How to enable device to save to memory card? Camera ok but dl apps it went to int memory. Can't find options to do that.
tnchsg
goto setting -> app -> then goto that particular app -> storage -> if can move, you click the change at the storage used
CrimsonSoul
Just got my new V20 for 3 days and so far quite happy with it. Bought it online during Sitex with free battery pack :)
