Xiaomi Mi Max
Yesterday noon time update mine from 8.1.2.0 to 8.1.3.0 Global Rom
kelvinti
OK Folks,
Just replaced my Mi Max 32GB with a Mi Max Prime 4/128. :s22:
Upon finished flashing from China ROM to Global ROM, I was immediately prompted to update to Global Stable 8.1.4.0 (12MB Only) from current 8.1.3.0 for 4/128GB. :s22:
Awesome! :s22:
Can't imagine that this is my 4th Mi Max in the past 4 months LOL!!! The side effect of eating too much roti prata! :s13:
OK Folks,
Awesome! :s22:
Hi, just want to ask is there any different between 32Gb vs 128Gb in term of speed and responsive ? Thinking of changing to either 64gb or 128Gb model !!!
Thank you
kelvinti
Thank you
I'm not sure yet as I'm still installing all my apps at the moment...:s13:
On paper, Yes! :s22:
On Practical usage, Not sure yet bah! :s8:
Starbutt
Anyone have problem fitting your mi max phone on existing car windscreen mount?
Just wondering if my existing mount is wide enough. Kind of like my existing mount for ease of mount and dismounting phone and will hate to find a new one if it's too narrow to fit the mi max width.
Sent from Xiaomi MI 4I using GAGT
bbcccc
Thank you
652 is a 8 core cpu, 4x1.8 GHz Cortex-A72 & 4x1.4 GHz Cortex-A53
650 is a 6 core cpu, 2x1.8 GHz Cortex-A72 & 4x1.8 GHz Cortex-A53
kelvinti
OK. Finished setting up my 128 now.
All good. Speed wise. Don't know lah. I must say feel faster as it is a 652 over 650 mah... Haha.
However, the 128GB storage is a super plus.... Load whatever you want. No fear of running out of storage space. :)
kelvinti
Before I flashed to Global rom. I noticed that China rom has Volte option.
Global doesn't have it.
Thank you for your feedback !!!
locknlock
Sad... bought and use for first day only run my games phone auto restart . Anyone experience this ?
kelvinti
mine is miui global 7.3 stable 7.3.15
can jump.straight to this??
download to hp and open from ota update can le ah?
wah miui global 7.3 stable 7.3.15 problem wif google app download..hmmmm
Cannot.
Update cannot be ran cross-Stable and beta rom. :(
Stable rom can update only Stable rom.
