HTC 10
chong
One more thing to note... HTC 10 does not support wma music format. Only MP3 files seem to work. No matter what music app I use, it refuses to play my tracks which are in wma format. So you got to convert all to mp3 if you want listen music locally on the 10.
I tried copying 2 randomly selected WMA songs to my HTC 10, and they played fine with both Poweramp and VLC. Google Music failed to play them.
If you're particular about audio quality and file size, try Opus. It has been scientifically tested to have the best audio quality among lossy codecs, is open source, and is continuously being improved further. A friend of mine drove his HD600 via my HTC 10 with 192kbps Opus files and was pleasantly surprised by the audio quality.
Opus homepage: http://opus-codec.org/
Use foobar2000 to easily encode: http://www.foobar2000.org/encoderpack
qyc_91
Google Music ignored WMA file in the system by default
bluedubsBB
Anyone have an issue with white balancing when taking pics? Especially when light is not so strong, the balancing tends to be more yellowish then white. Using Pro is a hassle most of the time when u want to make a quick pic. I thought the previous IU is more user friendly in this SENSE (puns intended) :s22:
durianpancakes
I didnt notice anything like that o: the only thing that I mind about the camera was the maxed out ISO for low light shots, maybe you can post a picture here so that we can see if we are facing the same problem haha :p
Crzaes: I have no other camera that can take it :p It is two small spots but it is still worrying.
bluedubsBB
Example 1 ~
bluedubsBB
Example 2 ~
