kelvinti
- Jan 5, 2009
Just updated my 64gb to 8.1.6.0...
Wah! You are always so lucky to get fast OTA..
Finally manage to have 2 SIM and SDcard at the same time.
The device protruding out is thin enough to fit on a soft case. but i doubt will work on a hard case.
No need burn SIM card or super glue, just the device and a double sided tape
Yes dual sim standby with sd card. A guy provided the link earlier in this thread, I just buy onlyWah .. where you bought this? Can share link? So it'll be still dual SIM standby?
Actually, I would cut a hole to cater for this. Anyway, the flat surface part doesn't really kana much impact most of the time.
New star selling 64gb for 289 on shopee incase anyone interested
4G小卡延長線
For those who are worried can look at the comments in the link page.
http://e22a.com/h.0wJIDW?cv=AANHCQXu&sm=f26a3a
this one......... For the device
Can use this, no need to spoil the sim card or permanently fix it on the SD card:
4G小卡延長線
I just ordered 4 pcs from tb
