Xiaomi Redmi 4
francislimgc
Nice to hear that Redmi 4 Prime support 4G +3G. May consider it later, as I still have Redmi S3 which support 4G +2G only.
hachi
Ok...thanks....snapshot of the spec display.
This one only slightly longer than redmi 1s i using....
5 inch n full hd...so might consider this since 3s only 2g.
Sent from Asus ME173X using GAGT
From mi store at suntec?
clay9477
Hi. So far do you have any issues? Like whatsapp delayed notification etc... Some of the previous Redmi 3 had this annoying issue.
Thanks
Stay with Redmi 3 for battery performance. Despite 625 chipset using 14nm compared to the 616 28nm, Redmi 3 battery life is better.
SBC
Upgraded my Xiaomi Note 1 to Redmi 4.
Day 1 today. Not bad for a $129 phone.
SBC
Redmi 4, 16gb model. Dark Grey.
Decided on this model for higher bat capacity.
SBC
SLS 03-40. Shop is selling at $199.
Paid on Shopee at $129 and collect on the spot.
notyoursister
i just ordered a redmi 4 prime from NSE thru lazada. now waiting for delivery.
Update:
Redmi 4 Prime = Redmi 4 Pro (RAM 3GB, ROM 32GB)
Phone received 2 days after ordering via Speedpost.
Cons:
- Xiaomi apps and random Video app ads (cannot be uninstalled but can be hidden by Nova launcher)
- Camera is sometimes good sometimes not. when it's good, pics come out very nice and focused. when it's not, comes out very shaky/blurry.
- I cannot find screen protector hahaha
- Sometimes don't get notifications from apps like whatsapp, telegram, instagram. UNLESS it is already open, then you will get the notifications.
- App links will direct to the Xiaomi app store, not google play store
- To download apps from google store, can only use WiFi. not sure how to work around this so that can use data.
Pros:
- very nice aluminium finish (abit like macbook)
- smooth UI
- BATTERY LIFE IS A BEAST
Note that i have GPS/Location Services on. Brightness is moderate. I have Do Not Disturb on because I don't want my whatsapp notifications to disturb my screenshots.
can't comment on fingerprint sensor as I dont use it. havent tried the second SIM also.
overall, damn happy with this phone.
Kyrogex
Update:
Cons:
Pros:
- smooth UI
Appreciate your input. Will you be using the second sim slot soon? Wanna see that 4G+3G in action
Sent from OnePlus ONE A2003 using GAGT
Byfrost
Quick question. The Xiaomi Store at Suntec, have Redmi 4 (or 4A) in stock yet? I'm looking for a cheaper variant and want to go there have a feel the display sets before committing.
weeza77
Problem downloading from Playstore only from wifi, need to disable MIUI Optimization.
