Nvidia Shield Gaming Tablet
artyboy
Its OK thanks. I'll see if any shops sell SP for Nvidia tablet over the weekend.
artyboy
Have ah, from Store for Geeks. $79 before coupon discount. Something wrong with the search engine at Qoo10, you do a search but it doesn't show, have to search by vendor name. I calculated price of Shield controller it seems to be cheaper than the US SRP price of US$59 so I ordered one.
BTW the Shield K1 is out of stock have to wait 2 weeks for next delivery.
koolkool
I just bought a Shield K1 tablet last week to replace my 3 year old Asus tablet and I'm impressed with this tablet at this price point. There is only one small observation is that occasionally I will get "Google play store has stopped" error. I got this error around 5 times already for past 1 week. Any one has this problem and if yes, how do you resolve this?
doki81
are you on latest fw? Have u try reset... If can please factory reset... I don't have such issue at all
Sent from Huawei NEXUS 6P using GAGT
koolkool
Thanks for your advice. I'm on latest fw. After checking when it occurred again, I realized the reason for this is because somehow the internal storage just disappeared... I need to restart to get back my internal storage. Quite strange.
Guys, ask you a question. Do u use adoptable storage? Is this stable? I read users have problem with this. I was thinking of giving this a try but now not so sure with the not so good review and my internal storage disappearing act.
xonix
Clear app cache & data, allow Google to reinstall Play store. See if situation improves before factory reset.
xonix
Internal storage how to disappear ? If so, nothing will be able to run.
I don't use adoptable storage on my Shield LTE. Purely for storage only.
artyboy
Guys, want to ask a question, is 1920x1200 resolution on this 8" Tablet sharp enough? I mean, can you see the pixels from a normal viewing distance? Do you get a decently crisp and sharp image?
xonix
Good enough for me. Can read marvel comics without zooming in most of the times.
D.N.K.
What sd card is recommended for this tablet and the shield tv. I will be using the card as adoptable storage so need speed not just high capacity.
jackycar
Anyone here using the shield k1, can you download Vainglory and play on highest settings to see if there's any stutter at all?
Reason is I changed from ipad air 2 to Samsung tab s2 9.7, now I have to play on lowest settings because it stutters during group fights 😒
Also, any good lobang for qoo10 to buy one? Cheapest I found is Amazon for 199 usd?
Also, can you play games from your steam library on this?
doki81
Reason is I changed from ipad air 2 to Samsung tab s2 9.7, now I have to play on lowest settings because it stutters during group fights �
mine is auto setting.. Graphic look impressive ady.. Everyday use it for vg :p can play 7 to 8 BR with no issue.
