Anything wrong with China ROM?Bought 1 from smartcell and came with global rom. Ordered another 1 from NSE came with china rom, so troublesome to flash. Zzzzzzzzzzzzzzzzzzzz
Sent from Xiaomi MI 5 using GAGT
Mine have. But I bought it 2nd hand. China ROM with gapps installedNo gapps installed. Got to install gapps separately...
So troublesome so flash! Will make a trip down to smartcell and see if they can help to flash for a small fee.
Android pay working with CM13?Took me 4 hours to flash to a custom rom lol. Alot of troubleshooting and googling involved. But well worth it. CM13 running smoothly without a hint of lag.
Applying for unlocking bootloader was less of a hassle than I thought. Applied on Saturday, unlock sms came on Tuesday 8am.
Have OTA updates often. Stable China ROM.That could be on a a tempered rom where there will not be any ota updates.
Or they installed gapps for you but if you factory reset your phone you have to install gapps yourself.
Oh.. that I not sure. Was supposed to flashed to global.. but afraid that I might hang it..Ic. Which means gapps will have to be reinstalled manually of a factory reset is done.
Hi guys, is mi5 available only through online purchases?
If I not wrong, all Xiaomi flagship phones no expandable memory.Did a google and it says mi5 has no external memory slot so I'm guessing 64gb is the way to go then?
Ya, need to unlock bootloader to flash gapps.
Now im having trouble to UBL. Ordered the special cable from aliexpress to try.
