_DeS__
- Mar 22, 2005
The miui forum say there's way to enter edl mode to flash the device. No need unlock bootloader.
i tried already. iirc miui 6 and above cannot enter edl mode liao.
I am totally aware they removed edl few mths ago for mi5.
http://en.miui.com/thread-446484-1-1.html
this is something new. post date is 21 dec 2016.
Personally I have not try this new method yet.
You can goto the mi max thread and see that they are still using edl mode as of now.
I just flashed a mi max yesterday. You can't use command prompt to enter edl anymore but you can still enter edl through pressing volume up and down together and plug in USB cable.Ya bro. But mi5 and max is 2 different models. Maxlovely also stated edl mode for mi5 is removed.
It gets warm when I turn on GPS and running google map. There's a few times I got the temp warning above 40 Celsius when running google map under and the phone under direct sunlight.Hi all, do any of Mi 5 units get warm sometimes quite hot to the touch on the top around the camera area? My unit runs quite warm only after short time of use, running latest global stable ROM v8.1.2. Is this normal?
Sent from Xiaomi MI 5 using GAGT
Normal usage no sign of warm to touch?
No, unless is gaming, it gets warm too
Can't wait to get the new update.Just managed to update to 8.1.4.0.
