rig upgrade
ZrE0_Cha0s
hey mates, came to a conclusion and this is what i'm getting and have gotten
i5 6500 + gigabyte b150m-d3h
corsair vengeance 2133mhz ddr4 lpx ram 2x8gb
sf leadex 550w gold
corsair 400c
wd 1tb blue
asus rog strix 1060gtx 6gb
dell u2417h
reusing, samsung ssd 850 evo 120gb.
any incompatibility? good to go?
nah shouldn't have any issues. so your budgets allows can go with it. though asus strix gtx 1060 enough for you to buy a cheap gtx 1070 thoguh.
MianBaoFren
sf leadex 550w gold
corsair 400c
wd 1tb blue
dell u2417h
All compatible I think. Just hold off your purchase and wait for kabylake. Out next week I think.
Sent from A Cat Who Does Not Need A Reason To Post using GAGT
morkutao
initially... it was a gigabyte g1 gaming, then qoo10 had a 60$ + asus instore 75$ discount, end up the card was 400. i think it was quite a steal though that's why i bought it! haha
morkutao
ZrE0_Cha0s
thanks for the tip! anyway for the kabylake. i heard it's only for the K series. which means i'll have to get an Z board eventually? i don't plan to do OC. what do you guys suggest?
lol not really. since there is non k chip as well.
just a h270 board. maybe wait for a little while and see if there is a h210 or b250 board and just get those board.
morkutao
so it'll be like i5 7500 + gigabyte ga b250m-d3h?
morkutao
read some release news and states that it's compatible with 1151 sockets. but any major problems with new chipset in an older version board?
Encrypted11
You only need a BIOS update containing a whitelist of the new CPUs. Some motherboards require CPU (6000 series in this case) & RAM to update BIOS, some can do it with just a power supply.
So you may need a shop's assistance to preinstall the new BIOS for you.
ragnarok95
Senior Moderator
Senior Moderator
Nope. You just lose out on the newer features on the newer mobo. Not like the newer features you will use also. :s13:
morkutao
haha ya! that's why i chose a business board. bang for buck can liao. haha. mainly used to do gaming nia. so, should wait awhile for kabylake? but 0.2ghz difference will be alot?
