the ONEPLUS 3
Synnexo
Grabbed the nougat update via opera VPN last night. Installation was smooth. Also clean my cache via stock recovery.
Everything looks okie so far. The thing I like most about the update is the DPI scaling and the default launcher setting now persists through a restart.
Previously the stock launcher will force itself as the default launcher upon reboot even though I set it to Nova. Now Nova launcher will start up properly after a reboot and I will no longer see the stock launcher.
In OB10, I experienced notification LED worked intermittently. So decided to revert to OB9, all well & smooth. Also, if u dun really use long screenshot, which the app can otherwise be downloaded in store, it's fine to go OOS 4.0.
riderxps
How to get to the dpi scaling and double tap to switch between 2 recent apps?
koreanlover
Have you tried with android pay? If it works with android pay (with UOB card), then it's UOB app issue, if not, then another issue.
Top up at GTM at MRT station works with Android Pay, looks like the UOB Mighty app has problems with Nougat ?
Using Nougat stable release for 3T.
batboyz
Nougat feature.
Complain to UOB. I have only used UOB mighty once at starbucks, but after Android pay was released in SG, I don't use any other pay apps other than Android pay, don't really see the point. If the bank does not support Android pay, e.g., Citibank (has fruit pay and citipay), then too bad for them.
Which app is useful to use with the DPI scaling? Chrome? :)
DPI scaling in nougat is system wide not app setting. I use the smallest display (higher DPI?) + smallest font on my N6P = profit.
adderrs
Thanks, I realized that is the case after watching the youtube video. lol... very useful indeed.
xiaosen
riderxps
DPI scaling in nougat is system wide not app setting. I use the smallest display (higher DPI?) + smallest font on my N6P = profit.[/QUOTE]
Okay, got it can adjust font,display and icon size to get more space.lol
getsomedonuts
Yes. Did it on my A3010 yesterday. Change to Canada to receive update and turn off VPN to download.
thanks! updated with no problems :)
Has it been released for Oneplus 3 yet?
Thought the links given earlier are for Oneplus 3T only.
thanks! i ended up using the Samsung USB C cable. My friend had it from the Note7 and she gave it to me since she no longer needed it
kennyboy
Local bank apps are mostly crap. Same goes for the app you mentioned.
MasK
FYI, when you enable double-tap feature, the single tap becomes less responsive (since it waits for that second tap)
Long-press is a better choice imho :)
bastero
Yeah I agree to that, tested it personally using timer heh. Definitely more responsive. The only double tap that I set is the home button. The left/right buttons I configured only to long press action.
riderxps
Noted with thanks
Skyy
35 as I find it quite bright.
Lol but I use it quite long or maybe 60% I on wifi. But when I upgrade to 3.5.4 the battery life took a hit to 4-5hrs so I downgrade back.
Sent from OnePlus ONEPLUS A3010 using GAGT
If you're rooted and on custom kernel such as Elemental, there's some interactive gov tweaks where some guy hit 14 hrs of SOT. But the installation process is a bit of a pain though because it doesn't support profiles unlike the same tweak on Nexus 6p.
adderrs
Not nice. For sandstone better to get those hard case.
I see. Those hard case sandstone including the official one from OP does not cover top and bottom leh... this is the only sandstone case I found so far which covers all angles. Mixed feedbacks from the taobao item page too, its a hit and miss where certain percentage of their stock do not fit the camera and lens well due to poor quality control.
