1. Removu S1 (splash proof, pre-order)
2. Feiyutech WG 3 (available locally)
Where can I buy the Removu S1 in Singapore?
Im using feiyu tech spg. Compatible with smartphones like iPhone 7 plus as well as action cameras like gopro because it uses a flat clamp so not limited to a specific camera. I think it should fit gopro hero 5 (i got a 3+). Got if off aliexpress. Blazing fast DHL shipping. Received it within 24 hrs. US$259 after US$20 off discount. It's about $360 sgd.
My GoPro Hero3+ Black can't turn on anymore... didn't drop it or kena water damage.
Any good places in Singapore that can repair GoPros?
Thanks!
try turn on with power supply and not battery..
Thanks!
Hi,
Need some advices.
Is there really a lot of diff in video quality between Hero 5 and Hero 4 silver?
I will only use it twice a year during my diving trip so wondering if I should invest in a 4 Silver(cos of back LCD) or a Hero 5 with 4K video?
Thanks.
Hi,
Need some advices.
Thanks.
Hero 4 silver is using Ambarella A7 chipset not capable of 4K 30FPS
Hero 4 black is using A9 chipset capable of 4K 30FPS
Hero 5 black is using A12 which is 2xA7 and this is cheaper than A9 and not as advance as A9.
This is why you see Hero 5 is cheaper than Hero 4 black.
My suggestion get hero 4 black or Hero 5. Why invest in Hero 4 silver unless you are paying it at $200
does anyone encounter problem using Hero5 with Sandisk Extreme 128GB?
keep having memory error when taking video with it.
Get a second hand 4 silver. Since using only twice a year. Also consider if your editing setup can support 4k decently else you are better off shooting fhd.Hi,
Need some advices.
Thanks.
Outdoor Sports Travel.. If they don't have and you're willing to wait, can order from Aliexpress, Banggood etc..Guys, just bought my gopro hero 5. Does anyone know where can I get a surfboard mount locally and how much does it cost?
