LG V20
eyz
I think that full coverage SP like this would be the best SP to use for our curve v20.
the I bought is not full coverage, and the whole right edge and the top left of the 2nd screen are not sticking down.
this full coverage SP edges are painted black, so even if the edges of your SP is popping up, you won't be able to see it.
as for shattered edges SP, I was rather impressed by Baseus line of TGSP, which I bought from TB. their shatterproof edge SP actually has soft rubbery edges. And the SP was really tough, didn't see a single scratch on iph 6 after 1 year of usage.
Unfortunately, they don't manufacture SP for other phone models.
For those looking for a full screen TGSP..
Can try to get it from Taobao.
I currently using.. Seem quite good.. No rainbow effect
http://m.intl.taobao.com/detail/detail.html?id=542647320214&spm=a2141.7631730.0.i2
Will remove the link if it is inappropriate.
mie28
You had me at "dint see a single scratch" then you killed me at "for other phone models" 😂
tiredman
Hi all may i know how n where u all download songs for ring tone arh ? N which apps can watch hk drama n movies ? Thanks all
MorningOwl
anyone went to moshi moshi shop @sim lim tower buy their v20 tgsp? good anot? $4.90 for one piece, $9 with pasting service.
And also, is it need a lot of skill to paste tgsp? never paste tgsp before.
eyz
i went, they said it will pop up. so i didn't buy it.
i bought mine from a shop at bishan, recommended by a fellow user. but it still pop up on the side.
i recommend this full coverage 1 i saw on carousell.
arrived_limited_quality_lg_v20_9h_hardness_black_full_edge_to_edge_tempered_glass_screen_protector_1479786890_950cbfb9.jpg
at least if the sides pop up, the black painted edges will hide those gap.
lgmw33
The tgsp I bought at Bishan is not complete coverage. So no reason for it to pop up le. Mine, so far so gd. Can fit all kinds of casing. I thought only full coverage sp more prone to pop up. :s11:
MorningOwl
Then which tgsp is good? No need full coverage. The film protector from LG when i got the phone now all scratches liao, see liao very moody sia. I msg moshi moshi thru carousel they said their tgsp will have a bit halo effect. Sorry to ask , halo effect means the sides of phone will have gap? And dusts will trap there? Is it like this ?
eyz
I think a full coverage TGSP would be better. it literally cover the whole screen, leaving only the top and bottom panel.
I just watched the LG V20 disassembly video, the top and bottom cap are easily replaceable. it's basically a cap clipped onto the main frame. so if we do drop our phone, a full TGSP would save our screen panel, and if the caps are scratched, it's easily replaced.
jusis86
why the camera auto mode so cui one? v10 auto mode damn sui, this one so jialat? people improve they deprove?
kopi22
Bo bian.... Its auto mode is like this. That's why I not using auto mode. Prefer the Manual "Auto" mode.
