Gaming Rig Specs KYM?
longsiew
Spend more on GPU. The rest use the cheapest will do.
But Personally I will go for a 1TB SSD. Install all the games in this SSD
ragnarok95
Senior Moderator
Senior Moderator
Forget about eVGA Gold series. The only series you can get from eVGA is their P and T series.
If you want eVGA Gold series, just get a superflower leadex gold. Period.
Encrypted11
SanDisk is in my blacklist as well. Samsung Magician cloning is the best out there imo, worked flawlessly when building for clients. Don't think Micron has such software to compete with Samsung's
Somewhere beyond Samsung 830 they replaced norton ghost with Clonix aka samsung data migration. No issues working it out, don't have partition realignment bs or software deactivation issues.
Hardware wise, in-house designed controller.. no reliance on external vendors for reference firmware so there's an edge on validation. Also usually the earliest in implementing newer power management states so the power efficiency helps a little with laptop battery life.
NAND chips also have the potential of being first hand picks than resold ones used by 3rd party SSD makers.
Xtremesystems has a write endurance chart showing a 256GB set going at 4.5 petabytes (4500TB+) before data retention issues, 6+PB before uplorry and there were no other ssds coming close. (Think the M4 was halfway there). They endurance way beyond 3000 P/E cycles. This was on a consumer drive.
But empirically, there are models with insane write endurance. I have 2 27nm MLC 830s. One has nearly 30k power on hrs. Other is nearing 20k zero issues from day 1 and will continue to use them.
Worth or not? Depends on the individual. But I would still go for SSDs from primary PC OEM SSD suppliers for validation and qc like Intel/Micron/Samsung. It's a personal decision.
Ark Law
Agreed. Post back from 2015 :s13:
Kingston is now on my blacklist for SSD as a result of their idiotic & unethical stealth NAND swap - AnandTech | An Update to Kingston SSDNow V300: A Switch to Slower Micron NAND
If you need cheap & reliable = Crucial MX100 MX300
If you write 100GB a day = Intel 730 750
If you like 5-yr warranty = Intel 530 540
If you using laptop = Samsung 840 850 Evo
If you got $ to burn = Samsung 850 950 Pro
Coincidentally, it also means: "Get SSDs only from NAND manufacturers" :o
