Finally after some hassle and exchange of some feedback simder pass me 128 silver ... So now back to my 32gb local December set for sale .. interested pls pm me ..
Sent from HUAWEI MHA-L29 using GAGT
Have you contacted them via phone?
Which platform did you order?
U reccomend the link...
I see!
Only one number wah! 6802 3655... Must keep trying one!
I see!
If no stock will shoppee inform me?
Coz, sometime, sellers just sit on it or have this mentality that and assuming that the buyers can "wait long long! No need to keep the buyers updated even there isn't any stock at the moment!"!Just call nobody pick up...wat time they open tomolo...They should but again don't trust into that too much as far as sellers are concerned! Sellers have received so much orders via different platforms. They may have missed anyone's order and fail to keep the buyers updated as they should be!
Instead, you message them or call them to push them for the right answer!Coz, sometime, sellers just sit on it or have this mentality that and assuming that the buyers can "wait long long! No need to keep the buyers updated even there isn't any stock at the moment!"!
Utorrent can allow save to sdcard, I'm able to do so with my last phone.
Tomorrow they are closed!
No it was no global MIUI 7. He asked me if I wanted to update 8. I said I will do it myself no problem.Hmmm... That's fast!
Official global rom loaded by them for your set?
I first order Lazada 369 go there ( I called 4 times before order that even though I order Lazada can self collect , he say yes yes ) later I went there he see order number and say no cannot self . So I got pissed off and told him why did u tell the. To come . So later he go inside and talk to boss and say . OK we will cancel ur Lazada order ,u order again on q10 we will give u the last set .. so I ordered on q10 at 389 with a coupon I had . So all in all got it at 389 .How much?????
Yes .. I am just scared to let them do like this Xiaomi.eu have custom Roms with ads . So better to do itt my self . Feels more like my device doing on my.own hehehehI see...since you can do it....quite fun also! I also like to do it myself...Feel some sorts of accomplishment! kekeke!![]()
Actually QC2.0 will give higher output cause the voltage will stay at 9V thru out, where as the QC3.0 will drop tp ~6.6V, since the current mostly remain equal--about 1.4A till 80%--9vx 1.4A = ~12.5W on QC2.0 vs 6.6vx 1.4A ~9.5W on QC3.0 charger.
My apology if the words I chosen had offended you, it wasn't my intention.
My understanding of the Qualcomm note is to shield them from any liability cause every its ultimately the phone manufacturer we are dealing with, not Qualcomm. The phone maker can choose how to implement the charging spec as long as its within Qualcomm spec. Qualcomm had been under fire by USB-IF cause anything above 5V on vBus is forbidden on standard USB cable, neither Type A or Type C. unless both device and cable are speced to USB-PD.
I will use Samsung S7 as example, the Qualcomm version use SD820 and all electronic inside are capable of QC3.0 but they chose to spec to QC2.0 only because their Exynos 8890 isn’t compatible with QC3.0. They probably did that to make both specs more consistent.
And my take on why Xiaomi never state QC on MiMax, I think the most main reason is the phone do not ship with QC charger. understandable cause it will bump up the price. Xiaomi strategy is to keep cost as low as possible and sell as cheap as they can afford.
I don't have the Mi Max with me anymore--given to my friend as his first smartphone--below is the charging ampere I got previously
The app measure current input minus phone power consumption, as you can see, some figure is very low or even 0.
Again, no offense to anyone, just sharing my finding.![]()
