the ONEPLUS 3
Synnexo
samuelong87
2 ways to update.
1. Download the full zip from https://forum.xda-developers.com/oneplus-3t/how-to/rom-oos4-0-nougat-op3t-leaked-t3523482 & Adb Sideload it. Note that all data will be wiped.
2. Install Opera VPN in your phone, change region to Germany & check updates.
Hi. Im considering getting the OP3T to replace my ageing N6P.
Would like to confirm if I do get the A3010 set on Oxygen OS, I can get OTA updates using the VPN method without having to wipe my phone data?
Just worried about having to constantly sideload updates.
And apologies if this has been asked before but I have been reading pages but still not sure.
benny888
Absolutely no such issues at all
Synnexo
VPN confirm can get OTA. Jus backup your data if u worry, or I would think its a good practice. All my data is stored in GDrive, so I'm always flashing the full zip.
Do note that if u using Beta, the OTA is Beta, not official.
mackie8
2 ways to update.
I successfully update i think..
Coz i have android 7.0 now...
I followed this
http://www.androidbeat.com/2017/01/how-to-get-android-7-nougat-oneplus-3-3t-right-away/
Downloaded the 3T file..moved to main storage... And go to manual update....
Sent from Google PIXEL XL using GAGT
batboyz
There is no need to sideload using oneplus. Update files can be installed through stock recovery, i.e., download the zip file, install in recovery.
VPN is also not needed, use the method above.
OOS 4.0.2 zip files:
OnePlus 3 OxygenOS 4.0.1 to OxygenOS 4.0.2 – http://otafsc.h2os.com/patch/amazon...gen_16_OTA_037-039_patch_1701140133_d0e81.zip
OxygenOS 4.0.2 Full ROM for OnePlus 3 – http://otafsc.h2os.com/patch/amazon...n_16_OTA_037_all_1701041839_aa64b084a40a4.zip
OnePlus 3T OxygenOS 4.0.1 to OxygenOS 4.0.2 – https://drive.google.com/file/d/0B0pr-ZA5b-1pcUpiWU45Y0Y5Tk0/view
OxygenOS 4.0.2 Full ROM for OnePlus 3T – https://drive.google.com/file/d/0B0pr-ZA5b-1paE9zMk01M1NFNk0/view
mackie8
i downloaded a zip file as well.. and go to local upgrade option...
i dunno if its correct... but after everything i already have Android 7
i forgot the oxygen os version... will check later..
planning to reset the phone before passing it to my brother..
will it go back to hydrogen os? coz my set is china but preloaded by oxygen by the seller...
batboyz
Well, if it was updated successfully to the intended version then I would say it was correct. No, resetting phone won't revert it to H2OS. However, you may want to reset it properly before giving it to your bro to avoid android security to be triggered, i.e., remove all your Google accounts before the reset.
samuelong87
Thanks guys! Very helpful!
Final questions though:
Will AndroidPay have issues with all these roms on the OP3T (A3010)?
Im asking coz I do use AndroidPay a lot coming from N6P.
And also are all fingerprint services working well? E.g. DBS, Paypal etc
batboyz
As long as you stick with official OxygenOS, i.e., official & certified ROMs, I don't see any reason why android pay wouldn't work.
I believe oneplus is also using the same implementation as Nexus imprint, hence not seeing any issues, unless oneplus screws up.
kennyboy
Won't go back, relax.
Ninjaboi13
I shipped to my company and DHL did not ask for any money.... lol. lucky... borderlinx under declared my phone to 1699 HKD... I did not kana any GST. total only pay borderlinx 40 sgd. lol
how much was the total cost including shipping and gst?
Skyy
AndroidPay works fine on stock rom. DBS banking app also can use the fingerprint
hellhole
aiyo... sneeze.. and now it all sold out.. from the hk website.. hahaha
aigh... wait again.. i guess
Muachee997
Anyone bought a cheap + good Dash charger? I'm looking to buy one for the office.
I know cheap + good dun normally go together.. but trying my luck.
Those that bought from Taobao? Did the chargers pump out 4A/good enough to provide dash charging?
oppo VOOC charger work fine for Dash. Is the same technology
