Huawei Mate 9
kenstyle
Anyone having WhatsApp notification delay?
Still like this has not been solved with the new software. Tried all settings and even asked Huawei and they suggested to reinstall the app. But still having same problems.
Getting very annoyed
ZhuTou!
Dun use any power saving mode
Do not close app when prompted under power intensive app
Dun set it auto close app when screen is off
Stay awake like below
Sent from HUAWEI MATE 9 using GAGT
zenn13
Hi guys, start using mate 9 for 2 wks, but im having this issue, when im oversea and get back to sg, i could not get any data network, tried turn on mobile data on and off also cannot until i restart my phone then back to normal. any one go this issue as well?
trd2970
Check the APN settings
zenn13
had check as u mention, all is correct only proxy,port,uername,password indicate not set. tried to reset to default and choose the apn for my plan and still show the above mention not set.
Swiftyz
I sold to my colleague liao.
It's not really heavy but the size will block the finger print behind.
I didn't used it and brought the red monster powerbank.
I like that it's not heavy, what do you mean block the fingerprint behind?
Like when you are charging and using the phone at the same time? Too big that it blocks the back of the mate 9?
XinSuiLe
hi, i have joined the bandwagon as well.
Can ask you guys if anyone using the original smart cover? how to change the background when i close my cover?
trd2970
Did u set the mobile usage data warning? Maybe exceeded.
