Xiaomi Redmi 4A
Tornesoul
redmi 4a vs redmi 2s, which btr ah? i assume 4a btr, but by much?
currently using 2s, worth the upgrade? using 1gb ram/8gb storage.
Tornesoul
It may be coming to Singapore~
↑Xiaomi 2016117 spotted in IMDA equipment database.
Xiaomi 2016117 is the Redmi 4A: http://pdadb.net/index.php?m=device&id=10935&c=xiaomi_redmi_4a_dual_sim_global_td-lte_2016117
im on imda website, how / where to find the database? looks pretty useful
ZrE0_Cha0s
i dun think u can both spec like this, since 1 is definitely using newer parts than the other old model.
and i would say yes its definitely worth the upgrade if u are a power user (meaning u want less lag with more apps opened and able to get good signal for your daily call, msg and internet on the go.)
but if for basic phone usage, its still quite ok to buy this as an upgrade.
hwbest
you should definitely consider redmi4 instead if lag is a concern to you
amazingone
Type ' Xiaomi ' in the supplier field ~
Redmi 2s?
There's only the Redmi 2, 2 Enhanced and Redmi 2A. I assume you're referring to the Redmi 2 (1GB+8GB) variant.
It can be considered a small upgrade in terms of storage, but I would say the regular Redmi 4 or the Redmi 4 Prime will be better~
Sent from my Xperia using GAGT
Kiwi8
Deluxe Member
Will recommend u buy the prime version with 3gb ram. Or can also consider buying mi max since the difference in price between the Redmi 4 prime and Mi Max is not that big.
uncle168
can i use either sim slot A or B for 4G data access or is the 4G physical fixed to sim slot A?
uncle168
slot A - singtel prepaid voice call & sms
slot B - m1 1gb data sim
most of the time i will only on slot A
when i need to see stock price, whatsapp or pcw @ edmw/ssi i will off slot A and on slot B
what i'm afraid that only slot A have 4G and slot B is static 2G only then i cannot do the above once singapore no more 2G from april 2017
hwbest
the only obvious negative about xiaomi's phones is lousy material, but this is why it's cheap.?don't use it as main phone unless you want to change a phone every year
amazingone
The material I would say is of a decent quality, not to an extent of lousy.
My Redmi 1S bought at the price of $169 is a durable one, drop many times on its screen face also no crack or whatsoever.
Same for my Redmi 2 too~
uncle168
i think for basic use is value for money
my redmi 2 was stolen in ikea tampines only use for 1 month 2 years ago :(
Kiwi8
Deluxe Member
Guys I ask u ah.
After unlocking my bootloader to install Global ROM, should I relock the bootloader? :o
Tornesoul
would love to get it or redmi note 4, but local nil yet unless import. dont rly wanna deal with flashing etc
Redmi 2s?
my bad, ya redmi 2. in terms of the specs is it redmi 4 prime > redmi 4 > redmi 4a?
i tried b4 friend's mi max, bth too big haha
