LG V20
tskeng
Ok my Gear S3 just prompted me that Samsung Pay is available and now through the Samsung Gear App in the LG V20, the Samsung Pay capabilities are now available.
Thanks for the feedback!
tohchr
I got mine from Singtel. Will it work?
Mind sharing the method?
Do as follows.
Reset your gear and uninstall the -3 Samsung apps. (Samsung gear, Samsung accessories, gear plugin). Then reinstall the 3 apps again.
-pair your gear to your V20 per normal. After pairing, off your phone Bluetooth to let your gear running in the "connected remotely". I realized only this way the Samsung pay will be push down to your gear. May take couple of hours to a day. Wait for notifications from the gear.
-when u received Samsung pay notifications to install in your gear, turn on your phone Bluetooth to connect gear to phone via bluetooth. On your V20, under general, security, turn on "unknown sources". On your gear, proceed to install Samsung pay and go thru the process till the end, it will ask u to install Samsung pay on your V20.
-head over to your V20, u will see the installation screen, proceed.
-done. If u get an error saying Samsung pay not supported when u start up Samsung pay, u need to wait for Samsung to update. Obviously they did not update certain batches to local, it's still under international gear variant. International variant yet to support Samsung pay.
hwsv07
Anyone notice the whatsapp notification volume is adjusted via the ringtone volume and not the notification volume? Is this the same for u guys?
ronrontan
V20 Phone Contacts Listing
Hi ,
Using V20 since a week, Great Phone especially the Audio quality! But in the Phone contacts listing is sorted according to First Name , Not last name as it is usually. I could not change the Contacts Listing . Tried so many times to find in the Phone Contacts menu but cold not.
Anyone knows how to revers the sorting order from First Name to Last Name???
Thanks !!
ronrontan:)
Oinkize
Hi ,
Thanks !!
ronrontan:)
Phone dial pad, contacts tab, top right 3 dots, contacts settings, display, sort by is there
tskeng
Do as follows.
Thanks for the Info. Before I could try it out, the samsung pay prompt appear in the gear s3 and I was able to push the capabilities down to my LG V20.
Thanks so much for sharing!
kevpaang
Hi,
Recently my home screen time/weather widget doesn't refresh itself anymore. Somehow, the time got stuck.
I got no app killer installed and auto interval at 1 hour but it doesn't seems to help.
Only method i can do now is either restart my phone or remove n add back the widget but few hours later, the time will get stuck again.
Hope someone can advise me. Thanks.
androidmazon
Pressing the small refresh button below the temperature doesn't help?
Hi,
tohchr
One question, after having Samsung pay, does your"connected remotely"still work?
troublesome58
My v20 on m1 keeps adding the free wireless@sg to the saved WiFi list. Anyone know how to get it to stop this?
eyz
how do you guys keep your phone optimize and running snappy?
my battery is draining is draining fast, and the UI is kinda draggy.
I can't wait for this phone to be rooted, and hope that there'll be a custom ROM for it.
