The Hair Thread - Part 4
evangel21
Uevo grey is definitely better than erratic.
works better and has this fixated fibre like hold
MM styling balm has strong hold and restyleability
depends what you're looking for
the closest but better product of erratic is uevo grey
Thanks! Looking for one that has strong hold. Is it necessary for MM to be used together with a sea salt spray? Not exactly looking for volume as I mainly do the messy spiky look.
Btw read that you have an online store. Mind PM me the link? Thanks much
xeonboy
its not a sea salt spray.
its another kind of volumizer
thanks, but i thought SSS is supposed to be a volumizer, as in, it gives volume to the hair. That's what I've been using it for all along. :eek::eek::eek:
What's the difference in their functions? :s11:
http://hairbroducts.sg/
gaoxing84
SSS = got sea salt as main ingredients.
Root lifting spray = more chemicals?
both have the same function, maybe SSS gives a more natural volume.
only in salon they use root lifting spray haha
gaoxing84
Sea salt spray will be good to give you the extra volume and helps to prestyle the hair shape for finishing with balm.
its good to have, and remember to always blow dry your hair before you style
xeonboy
thanks, do u sell any root lifting spray in your shop? :)
nichsong
Okay thank you. But i have heard that if you cut you hair short from the back and longer to the front. Your hair can hold longer. Just wanna ask if its true.
Sent from Samsung SM-G930F using GAGT
Most of the Quiff/Pomp hairstyles that people are rocking nowadays usually have hair shorter at the back, and a longer fringe. In general, having a haircut every 3-4 weeks will do you right. You'll see it's around that period where products tend to not work as well. Just rmb to get it trimmed and thinned out.. you already have the best product on the market now, in the form of Morris Motley :) It's all about understanding your hair genetics and behavior now
nichsong
Just tried out Uevo Green that I got from GX bro, and have got to say that I'm impressed! Despite what they describe about it having a 7/10 rating for shine, it's actually a really neutral, natural finish as compared to Uevo Grey having a dry matte finish. As of now, somehow found the experience to be better as compared to Uevo Grey, but too early to say as my hair is still relatively short (just cut).
But for the matter, did not use any pre-styler (again might change when my hair is longer). What I did was emulsify product into hands, and then scrunch my hair up instead of applying it root to tip like how most youtube videos recommend. I have found this method to be more effective for our hair type. Will update again as my hair grows, and will prolly post a full review of Uevo Green then too :)
Tower636
Hi all pls advise,
Recently i suffer loss hair and within 3 month my top almost bald see doctor take blood test and all normal.
Doctor say may due to stress!
Doctor recommend Minoxidil spray 5% use for 3 month no improvement and still lossing everyday.
But how come hair loss so rapidly fast!
Anybody have this problem?
nichsong
Hi all pls advise,
Really sorry to hear that bro, although hair loss is outside of my experience. But I would say follow your doctor's advice, or if need be, consult a dermatologist that specialises in scalp care. Apart from that try not to take hot showers and if possible use a gentle shampoo!
nichsong
Day 2 of using Uevo Green and its working blardy well. Really built for our hair type. Wonder why I didn't have the same experience with Grey LOL. Anyone tried both yet and can compare?
Rodon_Tan
whats the diff between uevo green and grey?
nichsong
The only supposed difference is in the finish. Uevo Grey gives a dry matte finish while Green gives a more natural Sheen. For some reason tho have found Green to work better with my hair.. But I won't conclude till my hair grows longer and I'm able to test and compare again.
