If you are referring to the living hall, yah lor it's so.Omg d1 is smaller than c6?a 4bedder smaller than a 3bedder?
Canberra MRT stn is definitely at BS's side. Just that got linkbridge to the BTO, Eastlink@Canberra.
Can any1 advise c6 and d1 living hall izzit same size?the only difference is only the 1more bedroom?
I got the floor plan in detail. C6 living room is 3690mm from wall to wall, D1 is 3850mm. Which means D1 living room shall be bigger a little bit.If u refer to the annex, it is not any smaller. c6 has an additional balcony in master bedroom. D1 doesn't. Size of master bedroom for both is approximately 20.1 (C6) vs 20.6 (d1) which is around the same.
For living room space, difference between d1 and c6 is around 4 sqm.
Again these are approximates based on unit breakdown.
I bought d1 because of efficient layout and number of rooms. Also there is only 1 balcony which is enough.
Hi, do you have the detailed floor plan for cs3a? Can pm me? Tks!I got the floor plan in detail. C6 living room is 3690mm from wall to wall, D1 is 3850mm. Which means D1 living room shall be bigger a little bit.
Sorry, I only have D1 and C6.Hi, do you have the detailed floor plan for cs3a? Can pm me? Tks!
Bro usually 4bedder living should be bigger although its with an extra room too so wanna know lolU shudnt compare in this way... 3rms vs 4rms?
If u chose C6 will have lesser 1rm.
So rm or living rm is more worth?
A slightly bigger living rm, after u put tings, carpentary work oso wil make it small again.
Ok thanks Bro for the info so it's like half a ft more for living which is agar my calculation from floor plan when agent show me. Should not be smaller right
So 160mm diff is 16cm (half a ruler length).. if u meant C6 & D1 abt same price means C6 high floor D1 low floor?
I really price are competitive, i rather take D1 than extra rm is better than extra half a feet lei bro..![]()
Oki. Happy shopping...lol Nono Bro paisei.what I mean is how come d1 and c6 although 1 is 4 bedder 1 is 3bedder yet the living hall for d1 is not bigger for the 4bedder
May you explain why ?
In my view,
Signature Price wise 4bm = 3bm premium of visionaire. (Rather cheap)
Sign units are all high ceilings
Quality wise not as bad
Of cos the location really bad, price appreciation will be slow.
Aside from that, did i miss out anything?![]()
Just wondering given a choice to choose between stack 38 and 54 level 1 which would u choose?38 like zero privacy but more open and the front don't have anything blocking
I find 38 better shud hav some bushes infront... lesser people swim there cos its like spa or relax pool...
But 54 not better bcos u will be facing clubhouse2, library, study corner...
People have function sure see & look yr unit...
noob question here...is balloting still applicable for already launched EC like visionaire? or can just walk in to book your desired unit?
Initially looking at 38 then wife was thinking too open if take afternoon nap must draw curtain and if people walk to main club house or to side gate will definitely walk pass. I also thinking 54 facing club house 2 people can see through but the only good point is got some bushes and tree to block but don't know it will be too dark or not.
Btw 38 don't have bush it's like those short grass patch in front only. With the children slide and play area likely more noisy?
