Xiaomi Redmi 4
belgarathc
Been on global rom for a while thanks to tip off from this thread, so far so good.
iammole
the 2.5D edge thing is really pain in the ass.... coz locally alot pple complain the screen protector doesn't fit.
anyone bought tempered glass screen protector for Redmi 4 Prime/Pro from china website that fits?
juuzbe
Hi I tried out the second sim slot already.
May I ask for the 2nd slot supporting 3G, is it only for voice? if we have 3G data can it be used to serve net as well?
juuzbe
am also keen to get one set of Redmi 4 Prime. Wonder if the gold and grey sets selling from Smartcell and Newstars are free from the infamous bezel/black border issue?
Kyrogex
No you can only use it for voice...
If u want to use data from 2ndslot sim, u have to set it as the primary card... which it will then become 4g and ur 1stslot sim become 3g
Sent from OnePlus ONE A2003 using GAGT
amazingone
ZrE0_Cha0s
not sure, unless the batch they got is the after 19th jan. but den again, who knows when that after 19th jan batch is been released?
ZrE0_Cha0s
bought, but unsure about it, since mine is a full cover TP so end up i din see any dust or bubble, but the one i bought seems like quite small and its more like for redmi 4 SD instead of PRO :(
juuzbe
Oh can set in the phone then is ok....instead of need to swop the cards over, very troublesome. Currently doing for the Redmi2 phone. Thanks for the info.
iammole
the common complains is the sides doesn't fit. Really dunno what that means actually.
Does yours:
- covers over the curved side or
-stops before the curved side i.e cover only the flat surface not the curved surface?
possible can show some macro pictures of the phone sides?
iammole
this you can never know.... so don't bet on it. You might get old stock, won't know.
anyway, if u put on this type of screen protector, the thick black border lines might become a non-issue.
note: the original thick black border lines is caused by the phone doesn't have the vertical borders. the "new batch" now has vertical borders. for pictures, see a few posts before this by another person.
ZrE0_Cha0s
Does yours:
I think mine didnt cover the 2.5D curve. just the flat surface.
XiaoFu99
Seems like the cheapest you can get @ Lazada is S$208 (before any discount).
Assuming 1.5% shopback + 7% SingPost Credit Card, i think the cheapest will be something like S$190.32 (without any discount code)
XiaoFu99
Can somebody confirm Redmi 4 Prime :
1. with global ROM, playstore and 4G+3G workable @ Singapore
2. Do seller preload global rom with playstore ? Or DIY ?
3. Is microSD card slot dedicated or shared ?
4. Dual SIM: dual nano or nano+micro ?
5. Support QC2.0 or QC3.0 fast charging ?
