LG V20
musicsg_com
Hi, I'm interested in getting this phone. Major plus points for the DAC. Any reviews from the users here? Previous owner of LG G4 which I think is having a bootloop issue.
I've just completed my review of the V20. Generally, it is like an upgraded G5, with the same dual camera, 24-bit audio and video recording, rugged body, larger battery. But battery drain is still quite bad when running some apps, and the lack of app manager means I cannot restrict background apps like some smartphones (Huawei Mate 9, for instance). Recommended to get extra battery just in case, or get a QC power bank for fast charging on the go.
http://musicphotolife.com/2017/02/lg-v20-review-premium-audio-dual-camera/
tiredman
Hi all any idea how to make the sound to phonr mode ? I accidentally mske it to headset mode haizx :(
kefkaway
file date stamping
Hi all,
I transferred all my photos from my old phone into the SD card and then put this SD card in my mew V20 and copied it into the phone local storage but noticed all the files have the modification date changed to the date I copied the files. This makes the photo sorting in Gallery go haywire. The time stamping did not change in the SD card when I transfered the files from my old phone. Anyone has this problem? Anyway to solve it? Thanks.
bedlamite
Seems like there's a new firmware update out
V10d-SEA-XX
Changelog is pretty vague though, nothing other than "phone improvements"
mds8080
Mine just gets hot sonetimes for no reason even though i didn't use it.
Sent from LGE LG-H990 using GAGT
Must be some rogue app running background processes. Common android problem but hard to find the exact cause. Last time I used DU Cleaner & Clean Cache. After running the app scan I did feel the phone was faster and didn't heat up. You might want to try this app before taking the trouble to go to the service centre
DragoMaster
Installed the new update, phone seems less laggy, last time after a reboot the phone will lag quite badly
