LG V20
mie28
Installed the new update, phone seems less laggy, last time after a reboot the phone will lag quite badly
Sent from LGE LG-H990 using GAGT
Think its just updates for December. Just updated, no idea what's new yet. Does feel less laggy but its probably just the mind psycho-ing me. 😂
spectral
Mine just gets hot sonetimes for no reason even though i didn't use it.
you might wanna check which app is draining batt and making the phone warm. I encountered few times batt drain in very fast and phone very warm and found out it was Google play services that is causing the problem. Force stop and restart seems to resolve it.
eyz
does anyone get the "network unavailable. try again later" error msg?
I get this error msg every now and then.
mie28
I got it last time when I use the manual selection of the network operator. Because the signal was weak, it showed up. Need to set as Automatic selection.
Was this the case for u also?
ronrontan
Imac Problem detecting and writing to 256 SD Card
I'm using 256GB Micro SD card on this phone right now
Hi
I use a 256 GB Sandisk SD Card in my V20. My Mac mini h as problem detecting it, after I reformatted it in my V20. Using Disk Utility to detect it but when copying to it the Copy Process stopped several times. I am copying 114 GB of ALAC files into the Micro SD Card.Anyone facing the same problem?? Any solution??
The V20 is supposed to be able to address 2 Terabytes SD Cards , for gods sake!!
Thanks in advance
ramius_mark
Hi
Thanks in advance
It's an issue with Mac OSX and file formats.
Your SD card is probably formatted to vFAT or exFAT.
I had the same problem with Mac OSX on a MacBook Air and my LGV10 w a 64GB card. Files were not copying across properly.
Solution:
www.android.com/filetransfer
Install the app on OSX, then it will recognise the phone and card properly.
Hope that helps.
Tip: for Audio, move away from ALAC to FLAC instead. It's far more compatible and better quality than ALAC.
eyz
no idea. I just selected auto, and will see how it goes.
thanks!
mie28
Updated too. No issues so far. Except battery drains are still quite bad when on android. Not LG particularly.
From previous experiences, seems that way too hence some other android phones have bigger battery. The previous Note 4 I was using though was initially bad on battery life after the upgrade to Marshmallow but they released a 2nd firmware update and out of a sudden, the phone could last the whole working day at standard Whatapps/browsing/camera usage. Which makes me think that the manufacturers have a big part to play on the battery guzzling issue. They could fix it if they wanted to.
-nzy90
Anyone finding the wifi speed erratic?
Me. Seems like a common problem.
Another problem is it doesn't switch to the strongest WiFi signal. I have 3 routers in my house and the middle one always not utilised cuz the V20 would have connected to the first router and won't switch to the stronger signal even when I walk to the middle of my house. It only changes to another WiFi signal when I walk to the end of my house and is out of the range of the first router.
tkdboi
same issue as u. it doesn't always switch to the right access point.
seems it is an Android 7.0 issue
