the ONEPLUS 3
vibranze
Check with you guys, for SingTel user, we are entitled for SingTel Wifi right? I found that custom ROM can't connect to it automatically, but stock ROM has no issue. I checked SingTel website, it said there's no configuration needed so I'm not sure what's need to be done for custom ROM to connect to SingTel WiFi automatically? Any idea? Thank you.
kennyboy
Don't use custom rom. :D
ufo8mydog
guys have u tried the official oneplus curve tempered glass? how was it?
looking for a good tempered glass for this..
i read that the screen can get easily scratch...
Anyone want to order the official curve TGSP? I think we can do a spree here and save on shipping charges?
rharish_21
But the official one will cut some screen area leh? if you search, there are videos showing that it will cut one or two characters on both sides of the screen.
Mclairs83
don't bother.
NONE of the TGSP in the market will be good for OP3/T
just use the default SP that comes together with it until u can't see it liao den use it raw.
LaksaTitan
don't bother.
Using phone naked, got scratch liao near capacitive buttons cos cannot find good SP
P R N D
Gotten the phone at 430pm. After setup, updated to Nougat A7.0
This phone is wow... worth every penny.
Lucky I pick the black front gun metal.
Sent from OnePlus ONEPLUS A3010 using GAGT
ufo8mydog
don't bother.
that bad huh. I was looking at the review in XDA. It seems like one of the best. If one of the best means "still sucks". Then I'll stick with the stock one. Hope the glass holds up and I don't the phone.
ufo8mydog
Not on VPN and manually pushed for system updates through the setting and it gave me 4.0.3 firmware. Running an A3010 set.
kennyboy
Then use one of those TGSP that doesn't have coloured borders. They look like they don't stick well to the edges of the TGSP, but imho it's less irritating than having the rainbow effect in dead centre of your screen.
LaksaTitan
The normal kind also don't stick well... Always get air bubbles even if I ask shop to install for me:(
