Xiaomi Redmi 4A
Sausage
so right now the only stock are export sets from shoppee and lazada?
mi store appears out of stock.
K202020K
I think if wanna use for another 2 years, 2GB 16GB storage definitely not a safe option. Some more is 5" screen. Today the de facto standard is 5.5 inch display.
Sent from RTA using GAGT
sonnawabit
anyone knows if the 4A is able to remove both front and back camera? looking to use this for red zone camp
Kiwi8
Deluxe Member
From a layman like me looking at the phone, I didn't see any part that I can remove the cover with.... maybe those handphone repair shop can help u.
But if u dun mind, u can always sandpaper the camera lens and that should be sufficient to satisfy the red zone requirement rite?
sonnawabit
oh! I did not know the back cover is non-removable... handphone shop told me camera is able to remove but I think they were thinking of a diff model. Do you have any alternatives for a decent phone that can remove camera? cheers
Kiwi8
Deluxe Member
Do u intend to put back the camera after your NS stint? If u are gonna buy another phone after that, then I suppose the sandpaper method is feasible? :o
sonnawabit
the phone is purely for my NS stint but i'd preferably like to keep the camera intact so I can use after NS
K202020K
Not everyone prefer such a large screen, and the memory combination is more of a personal preference to each individual.
Sent from an Xperia using GAGT
2GB RAM is not practical for Mi UI. Even Asus Zenfone 2 Laser has been upgraded with 3GB RAM 32GB ROM.
16GB ROM is not practical for Android 6.0 Marsh mallow as apps can no longer be stored on the external microSD card. In addition, Xiaomi has another two limitations : you cannot store data on microSD card if you're using dual SIM due to the hybrid SIM slot design & their operating system size is unusually huge, taking up a tremendous proportion of the 16GB ROM.
Audiology93
Don't forget the front facing camera as well, which means you'll be "scratching" your screen just to blur out the lens. So it's better to get it removed by the handphone shop you mentioned.
idrinkecoke
I realised the lock screen p/w dim out very quickily, before i can key in anything the screen lights out already. Anyway to rectify this?
