[Official] Aqua Computer Thread
Op_Valkyrie
Have decided to start an official thread of Aqua Computer great products since there have several inquires posted on water cooling products.
I personally had been an avid supporter of their products since 2013 and this year they released something very interesting on the market - the Vision product line!!
What is the water cooler of the future? This was the question we asked ourselves before the development of VISION. From this question came the idea to integrate a highly developed display into our water cooler.
During the development of VISION, we realized that there are also many possible applications as a stand-alone device for VISION. In addition to the pure display functionality, VISION has therefore been extended by variants with touch control and infrared receiver. A menu structure that can be operated on the device has been integrated and VISION has been extended by a whole series of inputs and outputs. Directly connected can be a temperature sensor and a flow sensor.
VISION has an aquabus connection in addition to a USB interface and can be supplied with power via both connections. Some VISION versions offer the possibility of integrated RGB lighting. VISION can also switch the PC on and off with an optional cable.
*Disclaimer - I'm not in anyway sponsored or directed by Aqua Computer to do this. Just wish to create some awareness and share their great products + technology for the water cooling/monitoring scene*
Waited 2 months for this to arrived... reckon I'm the first few lucky folks in the world to own these now - not to say Singapore
Box box box....
Unbox unbox unbox!
Pasar malam.....
replace anodized red side panel for my AMS rad 140 & 280
as promised - help bro phil hoot his aq6 pro and accessories
Cuplex kryos NEXT VARIO with VISION 2011/2011-3,
nickel/nickel
Even comes with Grizzly Kryonaut
The most advance water cooling CPU block ever sold...
Op_Valkyrie
VISION Glow connection terminal for kryographics
the brain of the Vision!
compare the size of the normal connection terminal with the Vision
difference between the active backplate connection terminal with the regular (difference with the hole at the side)
Op_Valkyrie
VISION Touch with internal USB cable
difference between VISION Touch with internal USB cable and the VISION Touch with external USB cable, IR receiver and ambient temperature sensor
VISION Glow table top unit with IR receiver and ambient temperature sensor
RGB + OLED display in action!!
Op_Valkyrie
the super premium - VISION Touch table top unit, matte nickel plating, IR receiver and ambient temperature sensor
that's one solid block of iron here.... :D
size and build comparison of the VISION Touch table top unit, matte nickel plating, IR receiver and ambient temperature sensor
vs VISION Glow table top unit with IR receiver and ambient temperature sensor
royfrosty
I was actually looking around just now till you posted.
Was actually interested in their Vision line up stuffs.
Was wondering the Vision Table Top version, what can it really do? Is it...
1. To read all datas from all vision connected sensors in the loop?
Or
2. It doesnt need the vision sensors connected, but able to read infos like temperatures in within the pc? Like cpu temps and gpu temps, fan speed etc.
Op_Valkyrie
Or
a quick glance of what it is capable of and more....
hint : look at the left side of the Vision tab
shadow84
And i thought this thread was Op_Valkryie's version of Ezbuy warehouse sales... lol...
Noirkw
Thinking of trying out my first WC built. What would you recommend for a first time builder ? EKWB or Aqua? Can I mix and match like rojak ? I like the aesthetics of the Kryographics block for the GPU
Op_Valkyrie
can rojak... but aesthetic better to match pair...nicer looking....IMO
Encrypted11
How come ish seal air tight like frozen fillet huan :s34:
Non OT necromancy will bend or not? :crazy:
Can no longer use the incoming 1080 wb :sad:
