Xiaomi Redmi Note 4X
Anyone has an answer? Cos im considering either phones.
Thx!
Note 3 Colours: Grey, Silver, Gold
Note 4 Colours: Grey, Silver, Gold, Turquoise, Pink
Note 3 Camera: 16 MP
Note 4 Camera: 13 MP
Note 3 ROM: 2GB or 3GB
Note 4 ROM: 3GB or 4GB
Note 3 RAM: 16GB or 32GB
Note 4 RAM: 32GB or 64GB
I have given you a short preview. But perhaps you should start considering making friends with google too :s13:
ZrE0_Cha0s
lol your placement of ROM and RAM are wrongly place should be the other way.
garychengjw
Collected my 4x from smart cell. Sadly it's not the black option as choosen. It's the silver on black. #emo
And it's on modified global / "international" ROM, gonna flash to China Rom later. But somehow I can't find fastboot files on MIUI download section.
Sent from HTC 10 | The Power of 10 using GAGT
ZrE0_Cha0s
tried using the buttons to fastboot? (which i cant rmb xD)
deckcard
i managed to download taiwan global rom -http://tw.miui.com/download-20.html#54
as they release 4x also. flashed and works :s12:
Which method u use to flash bro?
Going to recovery method just display a phone with a USB unplugged imagine
At the bottom it says pcsuite.mi.com or something
Whisper
Noob here. If never flash can use? My Samsung just died on me, need a hp without plan asap. This phone $225 within my Budget but it's export set means what other than no warranty? I can't and don't know how to flash as I don't have computer.
amazingone
It doesn't comes with true Global ROM, but some sellers may preload either modified China ROM or install Google Play for you.
Sent from an Xperia using GAGT
Whisper
I intend to buy from SmartCell since one bro in this thread bought from them. But he said he flash the ROM. so if I never flash, i cannot use? I went to SmartCell @ Lazada. It said global ROM. Means I insert my m1 SIM card can use immediately?
amazingone
Can use, but the ROM is not a legit Global ROM by Xiaomi, it's a modified China ROM masking as Global ROM. It has Google Play in it.
Better don't do things like banking on it.
