Do keep us posted on the outcome.
Sent from LGE LG-H990 using GAGT
cannot tahan so I called Sony just now. The CSO told me to do this:
a. Unplugged the TV powerpoint, wait for 5 minutes, then plug back and on power. Wait for at least half an hour to 2 hour (??). The LED will be blinking during that period.
b. If nothing happens, reboot the TV by pressing the power button and volume down button at the back of the TV at the same time.
c. If still no go, call Sony again.
will update.
Just checked (about 20 min later after step a. above) - LED now no more blinking but just solid green light. I waited for about 10 min, switched on the TV, the amber and green blinking light came back. Now I got to do step a. all over again and see how.
Update at 1945 hrs:
After waiting for 2 hours, the LED light changed from green/amber blinking to finally solid amber for a long time. I switch the TV on, green/amber blinking came back.
Did the reboot, problem is, as there is no display, I can't go beyond pressing the volume down and power button. I think there is a initial setup screen that need user input which I couldn't do. So no joy. Will call Sony tomorrow again.
