Xiaomi Redmi 4A
Kiwi8
Deluxe Member
I realised the lock screen p/w dim out very quickily, before i can key in anything the screen lights out already. Anyway to rectify this?
U can try to enable "Tap to wake" so that u need not press the Power button to wake up the screen.
Sausage
any other redmi 4 users?
how does the reduced number of cores affect your use
i am using meizu m1 note with 8 cores and it is quite smooth except for instagram which keeps freezing every few potos
wondering if the redmi 4a can allow continuous scrolling without getting stuck
mosmos
High Honorary Member
I think for instagram is the andriod app problem, even my phone with 810 cpu instagram also keep freezing when browsing many potos.
Sausage
i want to buy one on lazada soon to use the febraury coupons. but does anyone know which roms the following sellers sell with?
new star
global technologies
for redmi 4a can we reflash with other region roms or must we only use the same region roms?
Kiwi8
Deluxe Member
new star
global technologies
As long as your request to unlock the bootloader is approved, u can install any rom, including the China rom or Global rom.
But remember that the waiting time for the request to be approved might take a few weeks to a month.
ZrE0_Cha0s
Lazada?
That means if i buy from those HDB shop there's no warranty?
yup lazada official 4A have 1 yr wty.
those depends on it as well. but mostly are shop warranty. (I mean u need to see if it SG or export model.)
ZrE0_Cha0s
From neighborhood shop. Those very small ones.
oh ok, but did u see any form of IDA sticker or any words stating Xiaomi SG? if not probably that is modify china rom that feels like global rom.
u can consider getting a actual gobal rom or china rom.
idrinkecoke
Only some IMDA sticker. No xiaomi SG.
koala2004
Can't connect to home WIFI!
Hi, not sure if this has been posted before. I just bought a Redmi 4A but it just can't connect to my home WIFI, why is it so? How to make it connect? I also found all china made phones can't connect to WIFI, like Lenovo. Thanks!
ZrE0_Cha0s
which router are u using? and did u turn of 2.4Ghz? next have u tried near to the router (just a few m away?)
koala2004
M1 ASUS router. What is the issue with 2.4Ghz? Is it suppose to be on or off? On/off on the router? How do I do that? I have tried just 2m, also no connection. Thanks.
