Xiaomi Redmi 4
iammole
Redmi Note 4X also worth a look. Internal organs same as Redmi 4 Pro/Prime, but screen is 5.5".
Alot of colours to choose from. Typically $225 during discounts.
Kirakun83
currently using china rom n their keyboard sux. got any keyboard recommend to use?
rookie121
Unwanted apps
Hi,
Anyone know how to uninstall UC browser & UC News from Redmi 4?
Please advice. Thank you
bodymasterboy
anyone can confirm if there's a need to unlock the bootloader when flashing from china to global rom?
iammole
no need. just goto Settings, then click check update, the global rom will appear there for download ~1.4Gb for the current update.
unlock is for rooting the phone.
iammole
Nowadays screen protector quality quite jialat.
Bought from ebay.
Kiwi8
Deluxe Member
Bought from ebay.
U should try buying tempered glass protector instead of the plastic one. It is not too much expensive than the plastic one and even cheap tempered glass protector adheres better to the phone than a bad plastic protector.
iammole
is a tempered glass protector. I bought 2pcs, one adhere quite ok, the other is mine in the picture :s22: :s22:
iammole
anyone tested it yet?
can't feel anything except new bloatware from Google.... Google Duo.
feels like rooting this bugger to get rid of all these google bloatware. damn irritating.
and the not-so-nice thing is that this update gets pushed over without any confirmation. Only realised that it's downloading when I on my wifi.
ZrE0_Cha0s
but when i checked the MIUI forum i dun see a lot of ppl complaining about that "google duo" though.
else u can consider disable it?
ZrE0_Cha0s
Lol for the new update of the 8.2 they removed for r4p. I guess maybe there are still some bugs and issues. That's why they removed :s13:
fwl18
hi, do any of u experience shutter lag with the camera when taking photo? When i tried to take a photo, i need to wait at least 1-2 seconds before i can move, otherwise the photo will be blur. Auto mode
