Need Tips on picking pc parts
Shadowsage
Hmm i5 7500 seems good. What do you think about asus h270f gaming thou? And is there other mobo with wifi given like the z270e?
i5-7500 with asus h110m board (need flash the latest bios first to support Intel 7th series)
2133mhz ram
Stock cooler or Cryorig M9i. Up to you.
550w watt is more than enough to power i5 and gtx 1070 setup.
Sent from Overpowered Phone Mark III using GAGT
Shadowsage
Sure. Btw any ideas on monitors? Im thinking 1080p with 144hz. I saw samsung lc24fg79fqe and it seem pretty good for the price of 480-500sgd.
You don't really need it but please buy 1. stock cpu coolers are fugly in a custom build. air coolers are cheap nowadays.
Shadowsage
So my final build will be something like this.
CPU: i5 7500
CPU Cooler: Cryorig m9i
MOBO: ASUS h270f gaming
Memory: G Skill V Series 2x 8GB DDR4 2400
HHD: Western Digital Blue 1TB
SSD: Samsung 850 Evo series 250GB
Case: Phanteks Enthoo Pro Full tower
PSU: Superflower 650W
GPU: Palit gtx 1070 super jetstream
Current total is around 1.9k without monitor/ keyboard and mouse.
Need suggestion on a 1080p 144hz monitor. So is my build ok?
idjekyll
CPU: i5 7500
I might be wrong but your rig might be too up for a 1080p. Maybe look for 1 with g-sync. if not your fps all over the place.
singupingu
Using 1080p 60hz monitor and don't notice any tearing or anything :)
But getting a high hz 1080p monitor is awesome.
A note of warning to TS, ONCE YOU GO HIGH HZ MONITOR, YOU CAN'T LOOK BACK :s13:
lexmarq
I have the same i5-7500 + asus h270f gaming combo. Love the board. There is some in built RGB LED that may provide some aesthetics to the case. There is also the Aura RGB header which allow you to plug in a 12V RGB LED strip if you are into RGB lighting. All can be synchronized using the Asus AURA app in Windows.
Take note that there is no inbuilt wifi, so you either have to buy an external wifi adapter or a PCIe Wifi NIC.
Ghostyjangle
Is it better to get a wifi card or a wireless usb adapter? And if i bought my gpu on lazada how do i register my warranty? I bought palit gtx 1070 from digital stations from lazada.
lexmarq
wifi usb adapter or wifi card, I guess it's personal preference, although I feel that usb adapter is more convenient. Go with something which the cost is comfortable to you.
Regarding the warranty of the palit 1070, I'm not so sure. You can contact the seller on Lazada if the warranty is covered by them or the distributor. I don't think there's a need to register (correct me if I'm wrong, as I have never RMAed any component before), as long as you have the proof of purchase, that's sufficient.
