Xiaomi Redmi Note 4X
mr168
Hi I bought a note 4x over the weekend and it's a great phone with awesome battery life.
I want to ask whether my global ROM preinstalled by the shop is it a official ROM?
If not, if I flash myself would all data be wipe out?is there a link to teach how to do this?
Thanks
Can I know which shop did you buy it from?
aireth
Anyone gotten a proper screen protector? The one applied for me has a gap all around the edges because the screen curves...
My model number also says Redmi Note 4 instead of 4X though the box it comes in says 4X.
Sent from HUAWEI BTV-W09 using GAGT
garychengjw
Mine show 4 not 4X after flashing real global ROM.
I ordered this tempered glass. It's fully covered, the frame is make of TPU soft material. No gap edges. Perfect!
复制这条信息,打开�手机淘宝�即可看到【小米红米note4x钢化膜note4x全屏覆盖3D曲面软边防爆防指纹手机膜】¥rzPQPKQ3yG¥http://c.b1wt.com/h.WIbYoQ?cv=rzPQPKQ3yG&sm=20105d
Sent from Xiaomi REDMI NOTE 4X | Colourful Metal using GAGT
jerome9731
Finally managed to flash to this official ROM, google out the problem and managed to solved it.(miflash and the ROM have to be in the same directory)
The model number showing 4 instead of 4X though but phone working great, so i not bother by it.
Bought this note 4x on Qoo at $220+ self collect at Sim Lim Square on lvl 3, the shop seem to only deal with Xiaomi.
The glass protector didnt fit nicely at the edge, just order another one online from a different store to try.
Just like to add again, really love the battery capacity, great difference compare to my samsung
mr168
If you bought from smartcell, the phone will come with this rom.
tmengyew
Just to check for smartcell phone Global rom
1)is it able to OTA or have to manual upgrade .
2)Any self collect for smartcell or solely online?
3) if got problem any return policy for smart cell ?
Thanks
mr168
anyone notice the screenshot function a bit weird? after you taken a screenshot, the small thumbnail image keep "shaking"
ZrE0_Cha0s
mine r4p also the same, but that's fine so long i have my screenshot.
mr168
another quick question, wake lock screen for notifications doesn't work on stock sms app?
tmengyew
Yes
Thanks
Yes
1 week
Just bought from them on Sunday buy your own screen protector. The one they have doesn't fit.
Sent from Xiaomi REDMI NOTE 4 using GAGT
Thanks for your reply. May i know is this the address for smartcell mobile ?
185 Toa Payoh Central #01-346
Singapore 310185
ZrE0_Cha0s
Singapore 310185
should be correct, i last went was on the jan, but iirc its some where at the back of the courts (right hand side from its front)
