Kavairs
- Sep 10, 2013
Personal opinion right? Not creditable ley.![]()
Personal opinion that comes from someone who is playing BotW. Credibility still higher than you.
Interesting find. The Switch pulls 18W from dock, not 39W
39W is including the 2 front usb port. No wonder my powerbank can charge it as fast as the dock.
Hi guys...
Am going on a oversea work trip. Will be bring the Switch.
But if playing BoTW, it only last about 3 hours nia.
Any recommended portable power bank I can bring to charge during in flight? Else the Switch will die by the time I get off the flight.
Thanks
So any power bank will work? Just need to get the USB A to USB C
cable will do?
Anybody bought any accessories to cover the front screen of switch beside screen protector ? Like a front cover ?
Sent from HUAWEI LON-L29 using GAGT
Get a romoss battery. I like that it will auto cut off charging when device is charged full. Excellent for overnight charging. Also recharging it is fast. Just ordered another sense 6. Personal preference.
cable will do?
Powerbank with 2A output should work.
guys just a heads up, the rubber used to make the joycons are prone to fungal infection or degradation , it will rot in a few years time, its best if you buy some kind of cover for them to prolong their usage.
How come Makai Senki Disgaea 5 so expensive online? Physical copy cheaper?
You mean rubber on the analogue sticks?
I bought the Sense 6p (the newer version of Sense 6 and Sense 6 plus) last week but realized that it can only output 10w. You need 1 that can output at 18w to charge the Switch at full speed.
Hahah I only own two accessories nia.Wow everything also buy haha
Wanted to get 6P but 6 is like $12 cheaper hehe. I have sense 4 too. Even sense 4 is 38.5w, sense 6p only 10w??
Anyway i been using sense 4 to charge it while playing. It charge faster than it drain.
Actually i like it to play seperated. Hand relaxation![]()
No he should be referring to the Joycon itself. It seems to be coat with some kind of "rubbery" coating".
Dunno where u get your number but the Sense 4 does not output at 38.5w. It has 2 USB outputs and the faster port can only output at 5V x 2.1A =10.5W. The slower port output at a rate of 5V x 1A = 5W. Technically you can speak charge the Switch with 10.5W but it will not be charging at full speed.
