Nintendo Switch thread
rockdjlow
Blaster Master Zero review from Nintendolife.
http://www.nintendolife.com/reviews/switch-eshop/blaster_master_zero
Still waiting for Pro controller support on the 16th March. :s13:
Any idea how to play on 2 player mode?
XseanX
Just collected my switch, spend quite abit of time waiting for the shop to help me paste the sp, the staff went through a couple of hori sp before asking to switch another brand, but overall is satisfied with the workmanship & service. :)
Looks very good. Can share where you got it from? And is it easy to remove? Thanks.
I got mine at TOG Jurong point, perhaps you want to look around their branches.
mudxblood
What's the damage?
W3isheng
Screen protector if you want tempered glass have to order online. Local shops either oos or chop carrot price. I got myself locally a Hori SP, working fine (didnt melt).
Case wise, most of us got a Hori tough/hard/soft pouch, but its pretty much up to individual. Some of us also got Hori's joycon protector. Both of these can find locally, price maybe around 2 or 3 bucks more ex than online.
Any shop to recommend?
Kavairs
Not sure anyone mentioned this b4.....Does ur switch get quite hot after docking & playing long hrs on TV?
simcher
Yes, that's normal... the switch itself is wedge in between the dock... as Long as the fan is dissipating the heat from the cpu, it's ok...
StanII
are the bundled 3 Amiibos with the switch bundle useful?
any better ones to look out for if able to choose?
Nights
I bought xiaomi power bank 2 10000 model from challenger this evening. Play Zelda while using the power bank to charge Switch. Can really charge Switch to 100% even when I'm still playing the game :)
But I charge my power bank for for 3hours, the 4th LED still blinking. When I use it to charge my Switch, all 4 LEDs will blink. Is this normal? The packaging has no instruction manual also.
XseanX
What's the damage?
I got the local bundle with 2 games and free 3 Amiibos from Qoo10 @ $685 - $52 (coupon) - $18(GC 3% discount) = $615 (w/o consider CC rebate)
I think depend on what game u played, I have not try scanning yet but I believe they do at least have some usage like giving you some in-game item, better than nothing ba.. haha. :s13:
starsabre
games
i got my switch yest, so far only legend of zelda for games, anywhere can find new games?
Anyone managed to get into the nintendo eshop?
