Xiaomi Redmi 4A
ZrE0_Cha0s
M1 ASUS router. What is the issue with 2.4Ghz? Is it suppose to be on or off? On/off on the router? How do I do that? I have tried just 2m, also no connection. Thanks.
2.4Ghz : on
make sure the lights blinking on 2.4Ghz
hwbest
should be able to connect. i believe all of us here can.
Hi, not sure if this has been posted before. I just bought a Redmi 4A but it just can't connect to my home WIFI, why is it so? How to make it connect? I also found all china made phones can't connect to WIFI, like Lenovo. Thanks!
Kiwi8
Deluxe Member
Not sure. Sold by SingTel exclusive shop (Novel Comms)
I think it is still export set. They may be Singtel exclusive shop but they can still sell phones without bundling with the mobile plan.
Shadowly
Bought it for my dad for basic use. So far so good. It looks quite premium and does the basic calling, texting, WhatsApp well.. Used to replace his Mi 4i that up lorry. In terms of battery life it's better than Mi 4i maybe due to lower res screen.
lufu
Not sure. Has IMDA sticker. Cost close to nothing. Dirt cheap. So have no complaint.
Kiwi8
Deluxe Member
I got notification for Global ROM update today.
It's 8.2.1.0 (MCCMIDL).
Intrinion
Senior Moderator
Senior Moderator
Have a $40 challenger e rebate voucher. Should i get this or the 3s?
Intrinion
Senior Moderator
Senior Moderator
Have a $40 e rebate voucher from challenger :s13: - I can offset an item - looking at the Redmi 4A cause it's an easy flip. After deductions I will pay $109 thereabout. The Redmi 3S has quite a fair bit of network issues though, will be about $139
What is your usage pattern?
Btw are these two phones really close in price? I thought 3s is better?
Kiwi8
Deluxe Member
I see.... do note that 4A has only a Quad Core CPU, so if u are thinking of using it as your main phone, u might want to consider something better that has Octa Core CPU and higher RAM. :o
Intrinion
Senior Moderator
Senior Moderator
:o Have a iPhone 6s and a Galaxy S7, this would probs be a phone to play around.
