the ONEPLUS 3
ecneret_eel
I got the same problem as you.
Both my screen and WhatsApp has the same usage, 7% each.
However mine was mainly due to the mass number of notifications from group chat (few hundred to a thousand).
If not, you can check few pages back which I shared the link on how to improve battery life by tweaking the settings.
gamxiahamida
Sent from 1+3T using GAGT
KeYoKe
anyone ship from taobao direct before? i order some stuffs, then dont know where the item is now.
i check under my account, there are alot of items which i order, then got a "box",so i assume the "box" inside contains all my items? i try checking the tracking number, it says it is out for delivery. does that mean it will come today :s13:
mamboeidos
my dash charges order also..... but think unless got state in singapore if not can ignore ba... but for my previous taobao order, they will sms u to inform u if delivery for that day anot and the timing
KeYoKe
I got this:
dont know if this package contains everything
b3nji23
mine is full coverage. so far so good
i thought yesterday u posted the one that require u to put the oil one? how is it?
I got the same one as you. The full coverage tg but it seems that the touch sensitivity is abit affected. There is no good tg for 3t so far sadly :(
Kelvin0217
I got this:
Your package should contains everything and will receive today.
My package arrived Singapore yesterday 3am but still not reached the local warehouse as of this morning. Dpex told me that there is a lot of shipments from China this week thus there will be some delays in the delivery. :s22:
KeYoKe
cool. okok first time ordering thats why have to ask u, if not i blur blur...
mine reached SG on 7th March, today then deliver... quite long :s22:
Kelvin0217
Yes, normally if the package reached Singapore before 3am, it will delivery within the same day. If not, the next day. This time round it take quite long.
rAcEr
Like to get an extra oneplus 3 dash charger. Don't mind oppo one too, any where I could get them? Hopefully with 3 pin plug for sg variant. Will taobao or aliexpress be faster? Thanks
Sent from OnePlus 三 using GAGT
i was told u can find them at the original OPPO concept stores in Singapore. Chinatown, Geylang, AMK, Sengkang, etc. Should be approx 50 for the charger and the cable.
rAcEr
if anyone is interested, i have a used spigen ultra hybrid clear case for oneplus 3/3t...its in v good condition since used less than a week.
PM me if keen.
Gaghiel
am looking for type C to micro USB adaptor for OTG purpose, reuse existing cable. Can recommend working one. Too many out there, don't know which one works. Thanks.
kennyboy
edit : Actually, scratch that. Type-C to Micro usb adapter for OP3 doesn't seem to work as it should. I have 6 of them, of varying prices and quality, and none of them work if I plug a micro usb flash drive and then to OP3 via type-C. However, they all work for charging and plugged into PC via a micro usb cable.
This seems to be unique to the OP series. I've read of it happening to the OP2, so maybe that's that.
To be safe, a type-C to usb-A female works fine. And all flash drive/usb otg stuff basically comes in usb-A anyway.
