China Tablets to recommend
TUV2008
Just got a 11.5" RCA Andriod tablet from US with keyboard only at S$140. Good deal ?
produde1999
Do your own research here https://techtablets.com/
and know all the faults before buying. I'm happy with $100 iwork8 but the 4h battery life or resolution may put you off.
I bought it initially to play some low end game but too slow. and controls are difficult. In the end, I use a homebrew Vita.
I used it to watch HEVC videos... but in the end I bought a Mi Max phone which can playback HEVC video
Now I use it when I can't run certain program at work. E.g need to edit pdf or use photoshop which is not installed at work PC.
So ask yourself, why do you need it?
Ya got try playing vn on iwork8?
super365
I bought a teclast P80. I find the teclast P80 wifi is lousier than Samsung Galaxy S4 wifi when comparing both using at same location. Sometimes it just pause pause a bit here and there and struggle to load video smoothly.
Anyone finds that China tablets wifi is lousier than those handphone wifi?
Not sure is it maybe because better expenisive brands like Samsung uses better wifi components?
Also, Teclast P80 tablet even if I have fully charge and I do not use it for a few days never touch it, the power will auto deplete to zero and off in a few days maybe like 5 days. How many days will your tablet still have power if you never touch it?
yusoffb01
you should have researched before buying. All use lousy realtek. Another way to look at this is your house has lousy wifi coverage.
For battery issue, also do your research first. Of course standby will drain. you should properly switch off
Even when off some brands like chuwi still have battery drain. I'm using cube no such problems. I can off for 1 month and only drop a few %
touchme
can't take a sub-$100 tablet to cf.$200-500 tablets here.
I bought 2 units 3G-version for $70 each in 2015 (lazada), not expecting much, dedicated for car Navi/music/YouTube/Kara, and another for abusive tour use, 1g/8gb/8"IPS/3G/msd, good enough and serving me well since.
kaixin18
what do you think of this model? Just saw this on q10.
http://list.qoo10.sg/item/LOCAL-SEL...SIM-1GB-8GB-1GB-16GB/505895844#questionAnswer
I bought 2 units 3G-version for $70 each in 2015 (lazada), not expecting much, for basic GPS/music/YouTube in car, and another for abusive tour use, have been serving me well since.
I meant non-china tablets. Microsoft surface is way too exp. Any in-house reviews on HP, Dell etc?
Can recommend a windows 10 tablet for around $400?
I am aware the topic of this thread is China tablet but I don't find it necessary to open another thread
Any Cheap Chinese Windows Tablets (8 or 10) with AES/N-Trig stylus to recommend? I don't think the Chuwi tablet support AES/N Trig stylus?
As long as it is good enough to run OneNote, I'm happy already. Preferably 8-10 inches, though.
Thanks guys!
saw this MS tablet copy on a china site. LOL!
https://detail.tmall.com/item.htm?s...d=538139256367&standard=1&skuId=3214158648318
ykgoh
A lot of branded tablets are also made in China. Like ASUS and Acer. But why the difference in quality?
watzup_ken
I suppose its the QC involved. Also, the bigger brands may have a slightly bigger budget, which could also attribute to better parts used.
yusoffb01
vofzxy
cybertech
Anyone know of 8" ~ 10" Android Tablet with 4G LTE and with HDMI output?
Found the NVIDIA SHIELD Tablet (32GB, 4G LTE) but the other thread mentioned end of life :(
Seems like all that I search for got 4G but no HDMI port or got HDMI but only wifi :s22:
