better get warranty sets... regret..
My friend ordered a gold one. Came with official global rom sealed(china set as the writing on the back is in Chinese) so they probably resealed it after flashing to global rom.
Official global rom. I told him to try and update to the latest firmware via OTA and it worked.Real global ROM or fake global ROM
Saw on website. is 32G.
Redmi Note 4 (3GB+32GB, inGold and Dark Grey colour) available on 16th March at:
Its Note 4x since the FB post says that it uses 625.Good to know. If price is close, good to get local set. Hope Note 4 and 4x means the same phone. As base on Xiaomi miui site. Note 4 do have mtk and sd processor and there is also a note 4x.
Redmi Note 4
http://en.miui.com/download-309.html
Redmi Note 4x
http://en.miui.com/download-321.html
I believe local set is 4 and not 4x.
Just my guess , Most of them will be waiting for the 64Gb .![]()
Redmi Note 4 SD and Redmi Note 4X both uses SD chip.
Most of the specs are the same. The minor differences are on the blue tooth and the network bands. The 4X specs are better in these areas.
Refer to the link below for more info.
http://en.miui.com/thread-524344-1-1.html
It's note 4 Snapdragon 625 version.
4x is for china and taiwan.
N4 mtk
N4 SD
N4X
Sent from Xiaomi REDMI NOTE 4X | Colourful Metal using GAGT
I see. Thought they are the same since both are using 625.Redmi Note 4 SD and Redmi Note 4X both uses SD chip.
Good find!
4x is a better buy unless you only want local set
Both offers 32 and 64gb.Redmi Note 4 (not 4x) has 2 version. MTK x20 and SD625. I am not sure if 4 and 4x is actually same machine. Only know 4x has higher memory option.
This is a link comparing this 2 model.
http://m.gadgets.ndtv.com/xiaomi-redmi-note-4x-3994-vs-xiaomi-redmi-note-4-3713
