Intel 7820HK vs Intel 7700
croc1977
which is better in performance?
anyone advice?
Most likely specs is 1080 gtx and at least 16GB Ram...
laptop (desktop replacement)
harharhar
7820HK is a mobile chip right? Can't really compare to a desktop chip.
The desktop 7700 definitely better. And you can't find that in a laptop...
croc1977
sorry you are wrong...desktop replacement laptops
ragnarok95
Senior Moderator
Senior Moderator
7820HK has lower speed and is a 45W chip. 7700K has higher speed and is a 91W chip.
If you are not going to move the laptop a inch out of anywhere, just get the one with 7700K.
ragnarok95
Senior Moderator
Senior Moderator
i7-7700HQ is not the same as i7-7700 :s22::s22::s22:
i7-7820HK has 0.1GHz higher clock. You can get that.
https://ark.intel.com/compare/97464,97185
But if it's really the desktop i7-7700K, then get that. Definitely more performance than the mobile chips.
Go to aftershock website to see. They are using desktop cpu in their laptop. Aftershock is not the first anyway to use that. Don't need to roll eye.
Encrypted11
Aftershock is just rebranding clevo odm chassis.
And yes, there are clevo chassis that support socketed desktop cpus. Iirc even MSI also if that matters.
Its not like a mobile chip is totally not comparable to a desktop version. It uses the same 4C8T +GT2 (Intel HD) chip in a different packaging form, frequency and tdp.
That's before considering the same speed will cost more in a mobile chassis.
ZrE0_Cha0s
