Nintendo Switch thread
tremor
Pro controller is worth it. Very comfortable to use. I paid $129 but I gotten many days out of the extra money. And it's only 119 now, so no point hanging onto $99.
Nights
I pre-ordered early feb for $99 only, launch day they no stock. Till now no news. :s22:
Did you call them? I bought from TOG on 2nd day of launch day and bought another one a week after. Now pro controller selling for $129 already, how did you managed to pre order for $99?
teojjd
Hi do you guys experience any battery issues with the switch? Cause when I had fully charged my switch and then I turn it off and put in my bag at 8am so I could bring to work and then when I only turned on my switch at 1pm my battery is at 85%. Is it a firmware issue?
samuelong87
Had the same issue with battery draining even when on sleep mode or totally turned off.
My battery was defective. You should continue to observe and call up Maxsoft if it persists.
They gave me a replacement for the main console which is good. The downside is your saved games will be gone.
StanII
where to get at $119?
TOG original member price is $119 but now i see it as $127 instead
normal price still at $129
yes price increased from 119 to 127 for member from TOG
teojjd
Do you still have the same issue??
XxGaiaxX
He mentioned he got his faulty unit replaced and now its working well. You should get yours replace too asap before you have more save games on your console if possible. I left my switch in sleep mode from the previous night around 11pm to the next morning 10am, it eats like 2% of my battery only. So definitely something is up with yours.
chris888222
Yes it is ... 😁 planning to buy one in Tokyo this April ... if they already have stocks there? 😲 ... $490 are export set, much better than those sellng at local stores.
Hopefully there will be stock by then!
Japan is probably the cheapest place to get the switch amongst the major markets. Even $490 is quite a huge markup. Oh well, thank you maxsoft :(
Gametaku
i'm not even using the supplied charger.
am using a cable plugged in to the usb adaptor and charge.
Switch is sold as a home console and not mainly as a handheld. Most ppl buy it to play at home on their TV like what Nintendo has in mind. You need the dock to output to tv.
StanII
mine about 5% in 24hours, normal?
