Nintendo Switch thread
knightcover
While this is true for the case of USB A to micro usb or other legacy connection, this is not true for the case of USB A to USB C connection. USB C is designed to provide a higher draw than the older connection. By using an USB A to USB C cable, the USB C side does not recognize the USB A as a legacy connection. It still sees the USB A end as a typical USB C end and will thus try to draw as much current as the cable is rated as.
USB Type-A To Type-C Cannot Charge At 3A, Here’s Why
USB Type C and 3.1: clearing up the confusion
hi, can advise what kind of cables to get if i don't wanna dock my switch?
XxGaiaxX
Finally pulled the trigger, bought the 599 zelda bundle from qisahn on shopee! Very excited to collect it later. Any accessories to rec? I wanna get the USB cable for the dock, that one is USB C???
The standard will be a screen protector and a pouch to bring out. Some of us got the joycon crystal protector (Hori). And to use it outside of the dock, you need a male end and female end USB C cable.
lamecat
Which sp do you recommend?
knightcover
Thanks! The usb c male/female cable any physical stores to buy? I see that qoo10 or aliexpress selling at around 10 bucks thereabouts.
knightcover
Can i check if this is the right type to hoot? Kamsia and paiseh for the noobish questions.
jgyy1990
glass screen protector makes more sense as the screen itself is made of softer plastic
rockdjlow
Most I saw got amFilm brand tampered glass. But more troublesome, since it doesnt ship to SG directly from Amazon.
It does ship to Singapore, but i notice sometime they change the option not available to Singapore.
I ordered mine few days ago so just keep a look out when the option reverse back.
Gametaku
Dont buy any random generic usb c female extension. It will damage your Switch or dock. Not all no brand generic type c cable can carry the Switch video signal (Even if they do, u might face issue like flickering screen, loss of signal during gameplay etc). Buy the 1 from cablecreation. Its verified to be able to carry the Switch video signal with no issue.
NeonX
wow, just played zelda, took my switch out of doc.
its very hot. i think at least a good 70degrees
knightcover
thanks again for the input. I am getting this then, should be correct tio boh?
