Xiaomi Mi 5!
puteh83
last resort is to factory reset and install gapps or you can install global rom which already come with gapps
i had the same problem on my mi4c so i never use china rom ever again..... very troublesome
Haiz... wasted alot of time looking for solutions.
Last resort..go back to the guy who brought in the phone.. see what he can do..
I thought i'm quite tech savvy.. but this one really makes me bang walls. :mad::mad:
hahahah
Oinkize
hahahah
Just heart pain once and flash global rom. Easiest.
deckcard
hahahah
Uninstall Google services and use the Google installer found on MI store to reinstall again
yhw22
sorry, which Mi store version can work, those found in the web not compatible. can provide the link for downloading?
puteh83
Gotten worst. Wifi cannot be detected.
Wanted to do a clean factory reset but unable to do so.. not even a hard reset..
what the hell is going on man?!?!?!
happening lah. i didn't even do anything to the phone.
Updater auto download and auto reboot to the newChina rom Miui 8 android 7.
Now only thing that works is what i have downloaded. Playstore, wifi, all gone.
Anyone has encounter similar issues?
deckcard
Are you on china rom? You need to update the Google services to support nougat before any Google stuff will work.
Why cannot reset? BTW, you need Internet (WiFi or data) connection becos they need to disable find phone or whatever MI account stuff before you reset.
deckcard
How to update Google services?
Wifi cannot be detected..
Sent from Xiaomi MI 5 using GAGT
http://en.miui.com/forum.php?mod=viewthread&tid=543612&extra=page%3D1&mobile=2
The method I'd use is to download the 5 important apk (on apkmirror but u need the right version for v7) and install it starting from the framework->Google services->account manager->calendar then contact sync
Anyway, I think the thread already done it for you so u just follow it step by step
puteh83
Tried. Not working.
I have tried alot of methods from MIUI forums. all useless.
EDIT: WIFI suddenly working. Phone confirm going mad :s22:
Oinkize
Tried. Not working.
Seriously, better unlock bootloader and flash to global rom...
