Nintendo Switch thread
Gametaku
Ya, the kickstand is detachable. Just ring up maxsoft if yours is local set, see if they can help.
i know the kickstand is detachable. I am just worry that the fault lies with the console (the part where the kickstand fits in) and not with the kickstand itself. So after exchanging kickstand..it can lock in place without issue? Might buy 1 from Nintendo store itself.
Gametaku
This is how the issue looks like. Mine is every worse than this. This guy has to find certain angle then the stand will flap out.. mine just flap out all the while.
teojjd
Hi guys I just went to maxsoft to ask about the status of my defective battery on my switch, so far they had sent it for repair and will take 3 to 5 weeks for them to contact me. A staff in maxsoft said that the problem lies in overcharging (when its 100%) more than 8 hours. The staff said that you should only charge 7-8 hours on the first day and you should stop charging at the 100% mark. The staff also mentioned that if you overcharge the switch, the battery will either bloat or explode, same goes to all phones.
knightcover
ya, mine works fine now. Seriously, the kickstand is for sale separately??!
Kwein
but i normally play dock mode most of the time
always 100%
tremor
Sounds like bull crap to me. Nowadays charger and battery are intelligent. It's supposed to be a docked console, then cannot charge for more than 8 hours then how to function as a console?
Bull sh1t maxsoft.
Gametaku
Excuse lah. The switch is designed to be docked all the while without issue. While docking, it is charging too lor. Got ppl so eng..charge till 100% then remove from dock 1 meh? Most will just keep it in the dock unless they want to play portable mode.
teojjd
Bull sh1t maxsoft.
That's what they told me. Doesn't make sense either just warning you guys
XxGaiaxX
Lol maxsoft crap again. Pushing the blame to consumer instead of just admitting it's a faulty battery unit.
darkraider
You should ask for higher management to come out and education their staff what they are selling, how type c and Switch works.
Then ask for the case id they log with Nintendo so you can email Nintendo and cc in maxsoft.
teojjd
You should ask for higher management to come out and education their staff what they are selling and how Switch works.
The staff told me verbally and was trying to "solve " my problem asap as there are another switch customer who is having problems too.
