XxGaiaxX
- Apr 1, 2006
Anyone know where still have stock for switch casing? Need it quite urgently thanks
What type of casing? If soft pouch, funzsquare got stock.
Ya, the kickstand is detachable. Just ring up maxsoft if yours is local set, see if they can help.so replace kickstand will ok liao? not the set itself got issue? in that case, i mind cancel the return..
Those who got bomberman R please update the input whether got improvement not, this is the only reason i not buying yet.
Any type. I need a temporary one thanks !
i know the kickstand is detachable. I am just worry that the fault lies with the console (the part where the kickstand fits in) and not with the kickstand itself. So after exchanging kickstand..it can lock in place without issue? Might buy 1 from Nintendo store itself.
ya, mine works fine now. Seriously, the kickstand is for sale separately??!i know the kickstand is detachable. I am just worry that the fault lies with the console (the part where the kickstand fits in) and not with the kickstand itself. So after exchanging kickstand..it can lock in place without issue? Might buy 1 from Nintendo store itself.
Hi guys I just went to maxsoft to ask about the status of my defective battery on my switch, so far they had sent it for repair and will take 3 to 5 weeks for them to contact me. A staff in maxsoft said that the problem lies in overcharging (when its 100%) more than 8 hours. The staff said that you should only charge 7-8 hours on the first day and you should stop charging at the 100% mark. The staff also mentioned that if you overcharge the switch, the battery will either bloat or explode, same goes to all phones.
Sounds like bull crap to me. Nowadays charger and battery are intelligent. It's supposed to be a docked console, then cannot charge for more than 8 hours then how to function as a console?Hi guys I just went to maxsoft to ask about the status of my defective battery on my switch, so far they had sent it for repair and will take 3 to 5 weeks for them to contact me. A staff in maxsoft said that the problem lies in overcharging (when its 100%) more than 8 hours. The staff said that you should only charge 7-8 hours on the first day and you should stop charging at the 100% mark. The staff also mentioned that if you overcharge the switch, the battery will either bloat or explode, same goes to all phones.
but i normally play dock mode most of the time
always 100%
Bull sh1t maxsoft.
Sounds like typical Maxsoft BS to me!
You should ask for higher management to come out and education their staff what they are selling and how Switch works.
Then ask for the case id they log with Nintendo so you can email Nintendo and cc in maxsoft.
