Mastercard tap in TransitLink
Knightoftheblackrose
Same here. Just got the TransitLink email.
So the latest sequence is as follows :
1. Sign up for the pilot run via your MasterCard debit/credit card's issuing bank
2. ABT Transit link will send an email to you asking you to " activate" your account.
3. TransitLink will then send to you an email asking you to go to any of the GTMs in any train station. Place your card on the reader and follow the onscreen instructions to physically activate your MasterCard.
Just got an email from transitlink
I suspect they need to see the card at a GTM to deactivate its EZlink CAN number to avoid double charging at the gate. I hope this does not break EZlink at other vendors...
ActiveBlast
I was invited months ago along with uob offering the privimiles mastercard. They mentioned they going on a trial and was invited to try this pilot thing. Just received the confirmation to use it tomorrow. Shall give it a try
ActiveBlast
At the top up machine if I'm not wrong, you are able to default whichever payment you preferred
addict951
High Honorary Member
So tmr morning must go to ticketing machine 1st place my mastercard cc there and follow instructions to activate right??
invisible999
Does 'deactivation' mean that Ezlink function can't be used at all or only at bus/MRT.
If at all - the what's the point of such 'innovation'?
haydentan
Mine doesn't work. I suspect I select the wrong option at the GTM. Is it a yes or no when u select at GTM?
benlau1
Just tried using UOB Privi MC - just keep seeing bank card usage when you tap. Dunno how much you are charged also. Think will go back to using Ezlink
hyperbole
I will definitely go back. Just want to make use of the promos.
Honestly this system isn't ready to see daylight
chuanz
I just go check online and had a good laugh...
** Your transactions may take up to 3 days to be reflected in your account.
You may view any 7 days of your transactions, up to the last 90 days.
w4rdsg
Well it worked for my POSB Mastercard debit, but didn't show the journey cost, just "Bank card usage"
vince123123
Signed up via UOB website but received nothing to date. Have to manually do it via Transitlink's page instead.
addict951
Guys, for the DBS everyd card, only the 1st 3 SMRT rides are free right?
After that I should move on to the Maybank or the cimb cc?
Trazora
Yes. Need 3 days to process, so do it asap. Also think can only add 3 cards.
frustrateddude
From now till 19 September 2017, get a bonus 10%^ cash credit (up to S$8 per month) on your daily commute when you tap & go with CIMB Mastercard.
sauce
http://www.cimbbank.com.sg/en/perso...in-rides-10percent-cash-credit-promotion.html
T&C states $80 min spending
meaning
if from 20 mar to 19 April- travel expenses(by bus or mrt) cannot hit $80 (eg $79.99) - means no 10%?
and die die must hit $80 ($8 max rebate) as any amount greater than $80 means no rebate hor?
Or $80 min spending on cc on anything?
jtv_tm
Just to check, anyone has successfully added your FEVO card into the transitlink account?
addict951
tHANKS, Trazora!
sO NOW ranking all mc ccs in terms of max cash benefits
1. Everyd (1st 3 rides free)
2. CIMB mc, 10% cashback
3. Maybank mc, 8% casback
Correct me if I'm wrong
