Nintendo Switch thread
knightcover
yeah. but not often will get $20 on low price item. More than 30% off.
Plannin to get a cheap case for my switch on lazada too since i still have the 50% vouchers. Too bad they dont have screen protector that look good,.
where to get the 20 bucks vouchers? I only see the sgbday3 and citibank one. Thanks in advance.
blackgunner2
Any microsd card to rec? Sandisk class 10 ultra 128gb for 80 bucks on lazada is ok to hoot?
sandisk 128gb microsd is $37 after $20 off from convergent in lazada.. too bad i only learn about shopback after i made the purchase.. otherwise with singtel rewards signup bonus and shopperks can get another $13 off :s22:
Anyone had experience with the hori pitahara screen protector?
Using this case from Hori
https://www.amazon.co.jp/gp/aw/d/B0...switch+ケース&dpPl=1&dpID=41EyDdZWhML&ref=plSrch
and this screen protector
https://www.amazon.co.jp/gp/aw/d/B0...g_3?ie=UTF8&psc=1&refRID=82TTBXH5J6DX2C2SC3FF
no complains.. does the job.. the screen protector is also easy to apply
ElZedHaitch
screen protector is not glass right? I dunno if i should get a cheap glass one or one of these. Lazada have one from shopitree for about the same price as a cheap china glass one also.
Gametaku
Nintendo official fix for the Joycon desync issue.
Before sending it to Nintendo for repair:
After sending it to Nintendo (notice the black foam on the lower right):
I even tried removing the foam, and sure enough: The controller stops working properly when it's not there.
Its a conductive foam that's been specially treated with nickel, copper or both so it can shield electronics from RF interference. Please dont open your Joycon and add some random foam to it :s13:
ElZedHaitch
How long did it take?
jrwong84
Thinking about buying the binding of isaac see review like very siong to play
pegasus21
I think Japanese consoles have a red box?
Red box is only for My Nintendo Store purchased as you can choose what joycon and strap colour combinations you want hence they can't print the colour on the box. Normal retail sets in Japan use the same box that are available locally but has Japanese text on it.
ElZedHaitch
I hoot this from lazada on 21 march...see so cheap just grab, think will take some time to deliver but no hurry for me anyway..
When its too cheap and not local i will not buy. But let us know if its real or not. A lot of fakes around
Op_Valkyrie
That conductive foam company sure huat overnight.... imagine how many pieces they sold to Nintendo :s13:
