ZTE Axon 7
sparhawk699
Don't have. Bought direct from China via Ali Express and they disabled the OTA update function. I think it's a modded ROM that's why not recognized during Recovery Mode update from SD card also.... :s11:
Yup, I also notice that mine which I bought form Ali Express A2017 unable to get OTA, so I installed the Original rom from the ZTE website and now I get OTA for the latest patch for the Nougat. Mine version is ZTE_A2017V1.1.0B11
cyrilng
Ok cool. Will try out when free.
Nigelnkj
7.1 update is out for A2017G devices on either B11 or 7.0 via OTA
Side note: remove SD card when updating
Not too sure if it's just me but i couldn't update until i took out my SD card
First change i saw was the setting icon change
Sent from A Bottle Of Knee Gel using GAGT
technolust
Nigelnkj
My model is ZTE A2017G
Current build is A2017GV1.0.0B08
Everyday I keep Checking for updates leh :(
OTA for B11 is only for certain countries, especially for Netherlands as it was to fix some problems there.
You will need to download both B10 and 7.0 on Germany's ZTE site.
Apply B10 update before 7.0 update.
After 7.0 update is done check for updates. There should be a OTA about 400MB in size
Here's the website for B10 and 7.0 update packages
http://www.ztemobile.de/support/downloads/?product_id=2100#
Don't worry, it will be in English when you update as it follows the language you set on your phone
Good luck!
dbchoong
Got A2017G Nougat 7.1.1 OTA Update V1.2.0B01 installed, but I get problems with Play store. All installs will always get stuck with "Waiting for network".
One way around this is to set Play Store not to auto-update and then uninstall Play Store updates from Settings->Apps.
[Edit]
Fixed it by doing a factory reset. Now is Play Store is functioning OK.
Nigelnkj
No problems on my axon 7 tho
Used Waze app as a test
Download went smoothly
Have u tried doing a reboot after the update?
I always do one after every update
Please sic which dealer you guys bought from Aliexpress.
This Phone support Google Daydream liao.
Moi plan to hoot before out of stock.
technolust
Thanks bro, update successful. Never thought of all manufacturers, outside of Google itself, ZTE will be the first outside of Google with 7.1.1.
My wife is currently using it and she has no complaints:)
Good luck!
dbchoong
Android Pay does not work with latest A2017GV1.2.0B01 7.1.1... :s8:
